Author Topic: Oil Leak  (Read 3507 times)
Offline Ady TDI
Oil Leak
« on: 18 August 2008, 11:15 »
I have noticed quite a lot of oil on the drive where i park my car, is there anywhere specific i should be checking??
Offline Rhyso
Re: Oil Leak
« Reply #1 on: 18 August 2008, 11:17 »
sump would be my first point of call
then have a good nose around the engine bay
i assume its leaking oil at the front
Offline Ady TDI
Re: Oil Leak
« Reply #2 on: 18 August 2008, 12:29 »
Yeah at the front, just waiting on my neighbour to find my ramps i lent him so i can get underneath  :sad:
Offline Rhyso
Re: Oil Leak
« Reply #3 on: 18 August 2008, 12:38 »
how much oil we talking? i assume you've checked the dipstick to make sure there's some oil in there
Offline Ady TDI
Re: Oil Leak
« Reply #4 on: 18 August 2008, 12:44 »
There's quite a bit looking at the patch on the drive, i haven't checked the dip stick as the computer hasn't flashed up 'top up oil'
Offline Rhyso
Re: Oil Leak
« Reply #5 on: 18 August 2008, 12:47 »
i'd check that initially- might give you some indication of how much you've lost
did you experience any power loss etc prior to finding the oil?
Offline Ady TDI
Re: Oil Leak
« Reply #6 on: 18 August 2008, 13:01 »
Nope no power loss, will check the dip stick as well, my neighbour has kindly lost my ramps so cant get under it either  :sad:
Offline Ady TDI
Re: Oil Leak
« Reply #7 on: 18 August 2008, 19:18 »
Had a look and it seems to be at the back of the engine, so either the head gasket or rocker gasket
Offline richw911
Re: Oil Leak
« Reply #8 on: 18 August 2008, 19:40 »
Leak from turbo?
Offline Ady TDI
Re: Oil Leak
« Reply #9 on: 18 August 2008, 20:22 »
Leak from turbo?
That was my first thought, but there's oil around the rocker cover, will have to have a closer inspection
