Author Topic: VAG Booster  (Read 2009 times)
Offline matty4113
VAG Booster
« on: 15 August 2008, 14:41 »
Bought this today and went to fit it but cant find anywhere to plug in the little blue wire. Is it an earth??? any ideas where it goes or shall i just leave it off? Help much appreciated.
Matt
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: VAG Booster
« Reply #1 on: 15 August 2008, 15:39 »
the blue wire is like a remote cable...the whole amplified aerial is a tiny amplifier in itself so it needs to be powered up, hence the blue wire. if you have an aftermarket unit like say a sony with its own power loom, then it would patch onto either the remote or more preferably, the electric antenna out "ATT"
failing that and its the original radio, you would have to look at the radio pins at the back if there is an electric antenna output.
Do not patch it into an ordinary power supply, there are risks of damaging it that way despite the remote and att sending out 12v supplies also.
basically, you only want it to work wen the radio is on and the "tuner" function is activated as that is the only time you aerial will come into play. Remote is always on so long as the head unit is powered up which is the next best one to use but the "att" is the better one to use!
If it is any other radio but still has its own power loom, then you would need to patch it into the "blue" wire which may also be the "blue/white stripe" wire. but if there are both on your loom "blue and blue/white" then just patch it into the plain blue one!
Hope this helps. if you stil struggle then reply with the brand of radio that you have and i shall give you a more accurate answer of where it needs to go!
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
Offline matty4113
Re: VAG Booster
« Reply #2 on: 15 August 2008, 15:50 »
thanks for the quick reply, it is a sony xplod MEX-BT2500 from the head unit there is a block plugged in to it then a load of wires then another block then more wires that go through the dash somewhere.
Offline troublestarter
Re: VAG Booster
« Reply #3 on: 15 August 2008, 18:41 »
on your sony h/u there is a dark blue wire it will be labelled up amp remote or antenna
do not connect to what the other guy posted a ATT as that is the telephone mute input for a phone kit
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline matty4113
Re: VAG Booster
« Reply #4 on: 15 August 2008, 22:37 »
Many thanks Ruji and troublestarter, I wired  it up to the blue wire coming from the head unit. Wow it has found loads of stations i didnt even know you could get around this area. Im well impressed. Thanks again for your help.
Matt
