Author Topic: Differences between 17" and 18" alloys?  (Read 3142 times)
Offline Jimp
« on: 12 August 2008, 03:34 »
I was thinking of getting some BBS RR alloys for my golf and was wondering if there is much of a difference between 17" alloys and 18" ones? I know that 18" ones will have a rougher ride, but is it noticeable worse? How is the handling effected?
Thanks
Not low enough mk5
Not on the road enough mk3
Offline Gulfstream11
Re: Differences between 17" and 18" alloys?
« Reply #1 on: 12 August 2008, 07:09 »
I have recently changed from the standard 17" GTI wheels to the 18" pescara's and not noticed any change in handling at all.
I,m sure others will be more technical in their answers..
Gulf
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline neg
« Reply #2 on: 12 August 2008, 10:42 »
an inch...
Sorry, couldn't resist  :grin:
On a serious note I doubt you would notice the difference 'that' much from 17 to 18, less tyre wall roll as they will have lower profile rubber giving slightly better handling but mildly harder ride. Nothing to worry about, just get 19's ...  :wink:
Offline 182_blue
« Reply #3 on: 12 August 2008, 10:52 »
in the real world i doubt you will tell the difference
NewGolf
« Reply #4 on: 12 August 2008, 13:25 »
an inch...
*Cough* sorry, but didn't the GTI with 17"s on lap 2.5 seconds a lap faster than the same car with 18"s on, in the Evo tyre test?
18's look better, period. But 17's get kerbed less (more tyre sidewall), make the car handle better as it was designed to run on 17's, weigh less and accelerate a teeny bit better.
Also no white worm on the 17's, they cost less and are easier to get hold of. I chose them after finding the ride on a GTI with 18's on a little harsher than the 17's. Well happy with mine. Looks aren't everything  :wink:
Offline RedRobin
« Reply #5 on: 12 August 2008, 13:41 »
....Looks aren't everything?
:evil:
Offline scotgc
« Reply #6 on: 12 August 2008, 18:02 »
I have the 17's aswell, they look good enough and tyres cost enough in 17" form never mind 18" !
Offline Teutonic_Tamer
« Reply #7 on: 12 August 2008, 18:23 »
You ought to try budgeting for these puppies:
And being as its a <cough> Torsen <cough> quattro, all four need replacing in one go!  :rolleyes:
And as for those anchors, £300 ish for a set of pads, and over £2k for each disc!  :shocked:
I feel like a homo
Offline RedRobin
« Reply #8 on: 12 August 2008, 18:37 »
....^Ouch!! Expensive!! But awesome.
Thank goodness I'm generally not heavy on brake use - Only on spirited stints when circumstances allow and if I'm in the mood (whenever safely possible!).
Offline R32UK
« Reply #9 on: 12 August 2008, 18:41 »
2K for each disk???? :huh:
Im starting to think it would be cheaper to just drive into the wall!!! :grin:
