Author Topic: what turbo ?? 06A 145 704k k03 045 cf5019305  (Read 12967 times)
Offline MaXXeH
  • Golf MK5 GTI
« on: 11 August 2008, 21:05 »
what one is that boys?   ko3 or ko3s?
Offline GTi-Matt
Re: what turbo ?? 06A 145 704k k03 045 cf5019305
« Reply #1 on: 11 August 2008, 21:15 »
ko3s FTW unless u already have a ko3s then ko4 or garret mate :afro:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline richw911
« Reply #2 on: 11 August 2008, 21:24 »
Think he wants to know what turbo the part no relates to  :huh:
Offline MaXXeH
  • Golf MK5 GTI
« Reply #3 on: 11 August 2008, 21:29 »
i have a k03 just wanted a k03s
Offline richw911
« Reply #4 on: 11 August 2008, 21:29 »
I would say k03 if you look at the part no "KK03"
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #5 on: 12 August 2008, 00:08 »
I think the 045 bit relates to the K03. The "S" bit doesn't actually exist. The S turbos are K03-052/053/058.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline GTi-Matt
« Reply #6 on: 12 August 2008, 18:36 »
you fitted your new turbo yet ivor??
« Reply #7 on: 12 August 2008, 19:06 »
Yes, mate!!  :afro:  (I also got the sports cat fitted at the same time) although it's leaking coolant from the side of the turbo (still). :sad:  It's already been back once, so it's going back again on Thursday, & will hopefully get sorted this time.  (Along with a new R32 dogbone :smiley:).
I've also had the stage 2 custom code put on so it runs like a dream, now.  :smug:
Offline richw911
« Reply #8 on: 12 August 2008, 19:07 »
Good work :afro: You coming to the RR day?
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 12 August 2008, 19:19 »
another way to tell, 06A145704 tells you its AGU/ARZ.. so k03. AUM is 06A145713
