Author Topic: what turbo ?? 06A 145 704k k03 045 cf5019305  (Read 12969 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: what turbo ?? 06A 145 704k k03 045 cf5019305
« Reply #40 on: 12 August 2008, 21:32 »
AUM SHOULD have the K03-s from the factory, tho a few AUM's (for whatever reason) have turned up with a K03.  It's a lot harder to tell which turbo it is when it's on the car, I'm afraid. :sad:  If you can see & read the no's off the turbo (on the blue plaque), i can then tell you which turbo you've got.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline docaldo
  • 1.8t gti AUM
« Reply #41 on: 12 August 2008, 21:34 »
ahhh right cheers mate
Mrs Patterson you cheeky girl ;)
Offline GTi-Matt
« Reply #42 on: 12 August 2008, 21:37 »
IIRC wasnt it after 2001 that they came standard with ko3s's on  :undecided:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
