Author Topic: GTI 8v Brakes  (Read 4278 times)
VeeDubGTI16v
Re: GTI 8v Brakes
« Reply #20 on: 12 August 2008, 11:41 »
main issue with getting em from a scrappy is you need the car on the ground to crack off the hub nut, then you need the car in the air to get the wheel off :grin:
might be worth trying the screwdriver through the caliper into the disc bodge
Re: GTI 8v Brakes
« Reply #21 on: 12 August 2008, 11:49 »
hub nuts are done up to roughly 1 meeelion torques, so make sure its a bloody big screwdriver!  also this could bugger the threads in the hubs.
VeeDubGTI16v
Re: GTI 8v Brakes
« Reply #22 on: 12 August 2008, 11:55 »
what threads in the hub? where the caliper carrier bolts on? i can see the screwdriver/disc getting a bit f**ked though, thats why you borrow one from the breakers :grin:
a breaker bar combined with scaffold pole makes short work of the hub nuts :wink:
Re: GTI 8v Brakes
« Reply #23 on: 12 August 2008, 11:57 »
no where the wheel bolts to the hub, remember there are threads in the brake disc holes ;)
yeah I'm not saying you can't get them undone with enough leverage, but just imagine all that force being transfered to a screwdriver, if that was to suddenly snap you could injure yourself, plus its also gonna be applied to the threads in the hubs I cant imagine all that force will do em any good.
VeeDubGTI16v
Re: GTI 8v Brakes
« Reply #24 on: 12 August 2008, 11:59 »
oh, i was thinking with the wheel off
Re: GTI 8v Brakes
« Reply #25 on: 12 August 2008, 12:00 »
yeah with the wheel off, you know the big holes in the brake disc you wanna shove a screwdriver thru, thats where the wheel bolts thread into :grin:
edit: if you could get a mate to stand on the brakes that would be a better way to do it, but even then you may struggle.
« Last Edit: 12 August 2008, 12:02 by rubjonny »
VeeDubGTI16v
Re: GTI 8v Brakes
« Reply #26 on: 12 August 2008, 12:06 »
nah im saying screwdriver through the caliper in between the pads and into the vents in the disc
Offline WYATT
Re: GTI 8v Brakes
« Reply #27 on: 12 August 2008, 12:48 »
You can pick up 16v calipers and carriers alot cheaper than that on ebay. If your not in a rush I may have some you can have for £10 + p&p
What year are they from and also are they the ones most people say to upgrade to i have only been told by a few get the 16v one's ,
sorry im new to dubs and dont no too much
Cheers Joe
Re: GTI 8v Brakes
« Reply #28 on: 12 August 2008, 13:47 »
Hmm yeah that would work!
VeeDubGTI16v
Re: GTI 8v Brakes
« Reply #29 on: 12 August 2008, 14:25 »
i have done it like that before at a breakers with the car hanging from a crane getting some passat driveshafts off :laugh:
the screwdriver will have the stress along the length of it if its inside the disc brakes vents, not in one point like through the wheel nut hole so should be ok aslong as it isnt a cheap sh!tty one
« Last Edit: 12 August 2008, 14:28 by veedubgti16v »
