Author Topic: K-Jet in-Digi out!! Wiring advice!!!  (Read 1060 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 10 August 2008, 20:07 »
Just swapped a two litre eight valve with K-Jet injection, into my mate's digi eight valve. Wired the engine wires in, no probs. But....is there much difference in the wiring layout at the fuse box end? Only thing i noticed, was the bl00dy connectors are the wrong shape!!  :angry:
Offline Mr Blue
Re: K-Jet in-Digi out!! Wiring advice!!!
« Reply #1 on: 10 August 2008, 20:17 »
something diffrent!
Not sure if the wires are diffrent colour but check out Rub Jonnys mk2 fuse box wiring diagram post. Cant find it myself but its around.
Looks like a cut and join job
Offline richard s
« Reply #2 on: 10 August 2008, 20:24 »
why dont you swap kjet over to digi and everything is as it should be you just need to make sure engine is fitted witha 2e dizzy
Offline dan7
« Reply #3 on: 10 August 2008, 21:13 »
The engine is putting out 155bhp at the wheels running that set-up, so my mate wants the K-Jet to stay! I see your point! It would save me a headache, but i owe him a few favours! Cut and shut it is then! D@mn you, wires!!!!!
« Reply #4 on: 11 August 2008, 08:54 »
the fusebox changed in 1990, sounds like the digi was a 90spec car, k-jet will be pre-90 as they stopped doing em in 87.  gonna have to do a bit o splicing!
If I were you I'd pull out the bay loom again and seperate out the engine specific stuff, then splice that in.  being k-jet there wont be very much to do at all!
