Author Topic: 312mm brake upgrades  (Read 2844 times)
Offline the_stink
  • A3 140 TDI
« on: 08 August 2008, 12:25 »
so i have been using the search button to start with :grin: and found some bits and bobs but where is the best place to look to buy the brakes? As i ahvent got a clue what would need to be upgraded etc but when looking at the re mapp side of things this has poped up and is a valid point
more power + bigger brakes
hit me
Offline linz
  • vee-dub
Re: 312mm brake upgrades
« Reply #1 on: 08 August 2008, 12:29 »
honestly mate depends what ya want i got my entire upgrade kit off ebay
you may even be able to go to a scrappy ect and get the carriers ect
Offline Ridg
  • TDI - Soot Happens!
« Reply #2 on: 08 August 2008, 12:32 »
if you're already on 288mm brakes all you need is the carriers, these new cost about the same as a full set from a scrap yard / fleabay
you'll also need pads + discs
Offline the_stink
  • A3 140 TDI
« Reply #3 on: 08 August 2008, 12:34 »
are 288mm the standard GTi set up? im assuming ill need the whole lot? if that front and back, sorry to soudn so clueless  :tongue:
Offline Ridg
« Reply #4 on: 08 August 2008, 12:42 »
288mm is the standard GTI setup
your rears will be 232mm IIRC and those can be upgraded to 256mm
although most people say doing the rears is mainly cosmetic as they don't add as much stopping power as the front upgrade.
Offline the_stink
  • A3 140 TDI
« Reply #5 on: 08 August 2008, 12:43 »
yeah i just noticed that on antoher post and a link to vagparts etc with all the prices ;)
so for carriers,dics and pads looking at about £260.50
that sound about right?
« Last Edit: 08 August 2008, 12:49 by the_stink »
Offline linz
  • vee-dub
« Reply #6 on: 08 August 2008, 12:54 »
yh thats wat i apaid for my setup off ebay
Offline stmirren
« Reply #7 on: 08 August 2008, 12:58 »
Looking at this myself, is there a noticable difference from the 288mm on my GTi to the 312mm upgrade, or would better pads and drilled disc stop as good as the 312mm ??
Offline linz
  • vee-dub
« Reply #8 on: 08 August 2008, 13:03 »
http://www.golfgtiforum.co.uk/index.php?topic=88149.0
see pics of mine they look great and yes there is a noticeable difference
Offline Rhyso
« Reply #9 on: 08 August 2008, 13:42 »
hit me
did the search button return this
http://www.golfgtiforum.co.uk/index.php?topic=87778.0
