Author Topic: 312mm brake upgrades  (Read 2845 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: 312mm brake upgrades
« Reply #10 on: 08 August 2008, 13:45 »
Looking at this myself, is there a noticable difference from the 288mm on my GTi to the 312mm upgrade, or would better pads and drilled disc stop as good as the 312mm ??
I wouldn't bother with drilled/grooved discs in any size.  They're very expensive, more prone to cracking & wear pads out twice as quick!!
Pads on the other hand, is a different matter.  Spend £100-120 on some Ferodo DS2500's (or Mintex equivalent) for your 288's & you'll probably have more stopping power than 312's on crap pads.  (Obvoiusly those pads with the 312's would be immense).
The 312's definitely stop you quicker, but make the rear quite 'light' under heavy braking - You get used to it, though. :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« Reply #11 on: 09 August 2008, 01:18 »
