Author Topic: Manual Owners Changing Gear Noise?  (Read 10783 times)
Offline SteveS
  • GTI ED30
« on: 07 August 2008, 19:28 »
When changing gears usually into lower gears it makes quite a clonk noise under the bonnet.
i have looked and u can see the "arm" moving (under the battery) but it just seems very clonky sounding.... normal?
« Last Edit: 22 August 2008, 10:47 by SteveS »
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline 182_blue
Re: manual ed30 gear question
« Reply #1 on: 07 August 2008, 19:41 »
mines not clonky, only noise i get is a rubbing type noise when pulling away in first
Offline SteveS
  • GTI ED30
« Reply #2 on: 07 August 2008, 19:46 »
almost seems "loose" really hard to explain.
if i push it reasonably quickly between 1 and two (while stopped engine off whatever) it makes quite a sound like im whacking it in really hard!
SteveS
Offline candy turbo
« Reply #3 on: 07 August 2008, 21:50 »
i think i get a bit of this too , only if you pull off with really low rev s , other wise gear change is spot on
clubsport S no 215
Offline SteveS
  • GTI ED30
« Reply #4 on: 07 August 2008, 21:57 »
its not when moving off, nothing to do with revs, i could be idle and move the stick from 1st to 2nd it makes the "clonk"
SteveS
Offline SteveS
  • GTI ED30
« Reply #5 on: 21 August 2008, 18:46 »
still finding it really "clonky" when changing.. no1 else getting it?
SteveS
Phil mcavity
« Reply #6 on: 21 August 2008, 18:47 »
nope  :smiley:  :wink:
Offline CocoPops
« Reply #7 on: 21 August 2008, 19:20 »
thats because
a) it's standard
b) it's dsg
c) the esp keeps cutting in
d) the driver
 :lipsrsealed:
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline SteveS
  • GTI ED30
« Reply #8 on: 22 August 2008, 10:46 »
bump for manual owners only!!
SteveS
Offline stealthwolf
Re: Manual Owners Changing Gear Noise?
« Reply #9 on: 22 August 2008, 17:25 »
TBH my gear changes have been really quiet.
When I can face taking the ED30 out again, I'll feedback.
How long you had your car?
