Golf mk5
ED30 Sport Mode Blue Fin Remap DSG
Topic: ED30 Sport Mode Blue Fin Remap DSG (Read 1059 times)
Pisto1981
07 August 2008, 13:48 »
Hi, I noticed today whilst showing a friend the speed of my car that when the car is in sport mode its revs right up to 7000rpm, way into the red. I think I was in 4th as well. has anyone else experienced this and will this harm my car?
Hurdy
Serious forum addict
Re: ED30 Sport Mode Blue Fin Remap DSG
07 August 2008, 13:54 »
Some remaps can elevate the rev limit. The only time to start worrying is if it bounces off the redline at full throttle, rather than simply changing up
Seat Leon Cupra Black
290
DSG
Pisto1981
07 August 2008, 13:57 »
Thanks Hurdy. I have also noticed that when cruising around 40-60 the rev seem to increase then decrease on there own accord. I have spoken to a friend and they seem to think that the valve timing is out due to the remap???
Hurdy
07 August 2008, 14:29 »
Cruising between 40 and sixty in D mode would mean that you would probably be varying between 5th and 6th gears(4th and even third if you put your foot down) and hence the revs will vary too. When you get this variation, do you watch for the gear changing in the MFD? If you aren't changing gears then there is something amiss if the revs are varying and there is no respective change in speed. In S Mode you will be in either third or fourth gears at 40-60mph, but generally in S mode you wouldn't tend to get as much swapping of cogs. You definitely shouldn't be getting rev variation at a constant speed with constant pressure on the accellerator.
290
DSG
Golf mk5
