Author Topic: G60 VR6 Clutch Upgrade.  (Read 253860 times)
Offline richw911
« on: 02 August 2008, 20:12 »
The 1.8T comes with a dualmass flywheel which is recommended to be replaced when you replace the clutch.
The standard set up is not ideal if you have engine mods - remap exhaust etc.
The popular alternative is to get rid of the dualmass flywheel (Which is very expensive to replace) and replace the clutch so it can handle more power.
Once replaced with the G60 flywheel you wont ever need to replace it again :afro:
The singlemass flywheel is from a Corrado G60 (Also slightly lighter than the standard dualmass.) and the clutch is from a Golf MK3 VR6.
Its a straight forward bolt on job - For 5 speed models.  :wink:
*Note this set up Will NOT fit the newer 6 speed 1.8T's.*
http://www.high-impact.net/transmission_and_gear/DualMassvsSolidFW.htm
Please Note:
This set up WILL make the clutch VERY light.
You will need:
Corrado G60 flywheel vw part no: 028105269bx
The flywheel is £88.38 + vat
There is also a £25 surcharge if you are not exchanging the flywheel (Which if doing this conversion you wont be!!)
*Edit*
Thanks to Ivor Mk4 Turbo - keith
 Apparently, the G60 fly is the same as found in the Mk3 GTi 16v (ABF), so you can buy one from a scrappy for a tenner, then use it to exchange for a new one at VW (£80).  Then just buy the VR6 Sachs clutch for ~£100 - Job done!
OR ABF flywheel part number: 037 105 273 C
Golf MK3 VR6 3 in 1 Clutch kit - You can get one here: http://www.vwspares.co.uk/g3clutch.php
 I paid a bit extra because i wanted Sachs.
Sachs 3 in 1 kit - £119. Sachs Part no: 3000384001
Tho if you are not bothered about the make you can get one from eurocarparts or GSF a bit cheaper (Around £80 LUK are also a good clutch.)
The release bearing for the VR6 is the same as the 1.8T.
Bolts: You need shorter bolts for the flywheel vw part no:  N90206103 x 6
And for the clutch pressure plate bolts vw part no: N10101001 x 6
 £15.86 for all 12 bolts.
You can also buy this set up complete from Ebay, be careful though and use a tried and tested seller :afro:
How to guide http://myfastgti.com/volkswagen/threads/12367-2004-Mk4-1.8T-Jetta-GLI-GTI-Clutch-Replacement
The writer of this guide and GolfGTI.co.uk accept no responsibility of damage to your car when using this guide. Use at your own risk.
« Last Edit: 13 March 2012, 21:34 by richw911 »
Offline Gozza
Re: G60 VR6 Clutch Upgrade.
« Reply #1 on: 24 November 2008, 12:02 »
Hmmm, my brother just got his clutch replaced at a cost of £499. Is that pretty expensive or is it me ? They did exactly as you mention changing the clutch for a VR6 item and got rid of the dualmass flywheel.
Thanks ;)
Offline richw911
« Reply #2 on: 24 November 2008, 18:29 »
Thanks ;)
That is a bit expensive TBH, I got mine for £360 fitted  :wink:
 Never need a new flywheel ever again now tho :afro:
Offline BG-MK4
« Reply #3 on: 27 February 2009, 14:10 »
I also got the VR6/G60 kit, the price was 450$ fitted. Can anyone tell me what's the maximum power that this kit will be good for?
Seat Leon 20VT4
Offline richw911
« Reply #4 on: 27 February 2009, 18:58 »
250bhp and 300lbs torque  :smiley:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #5 on: 27 February 2009, 20:20 »
Even the LUK??!! :D
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline richw911
« Reply #6 on: 27 February 2009, 23:12 »
Even the LUK??!! :D
Possibly not!!  :grin:
Offline BG-MK4
« Reply #7 on: 28 February 2009, 18:11 »
I have the Sachs kit
Seat Leon 20VT4
Offline iMation
  • G SiXtY
« Reply #8 on: 28 February 2009, 18:16 »
Spot on guide Rich
Meh....
Offline richw911
« Reply #9 on: 28 February 2009, 20:38 »
