Author Topic: G60 VR6 Clutch Upgrade.  (Read 253549 times)
Offline BG-MK4
Re: G60 VR6 Clutch Upgrade.
« Reply #20 on: 08 June 2009, 23:44 »
Is it going to fit to Audi A3 1.8T AUM Quattro 5-speed?
Seat Leon 20VT4
Offline Mr_Orange
« Reply #21 on: 09 June 2009, 16:48 »
Looking into this at the mo.  Just got this all priced up:
VW G60 flywheel (028105269bx), its now £114 + 30 surcharge.  I haven't got the exchange so I'll be hit with full wack.
VW Bolts:
6off N90206103 @ £2.43 each
6off N10101001 @ £0.40 each
Quoted £100 + vat for the Sachs VR6 clutch kit (3000384001) at local motor factors
Also quoted £160 fitting.
Jobs a goodun, just got to convince our lass to raid the savings again.....  gulp
« Last Edit: 10 June 2009, 12:18 by Mr_Orange »
Build thread clicky
Offline richw911
« Reply #22 on: 09 June 2009, 18:42 »
Yes  :wink:
Offline Mr_Orange
« Reply #23 on: 17 June 2009, 19:45 »
VW Bolts:
Right, had it done.  Got a squeek now!  Furk it :cry:
Gets slightly louder with clutch depressed.  Up under car seems maybe from the metal gasket (between box and engine), could this be rubbing on the new flywheel?
Decided to give it a couple of days use use and see if it gets better.  It seems more noticable when cold....
Apart from that the clutch is lighter, but bite point etc feels so much better than before!  No vibration through clutch pedal, result!  Engine spins up/down more freely too.
« Last Edit: 19 June 2009, 12:12 by Mr_Orange »
Build thread clicky
Offline Mr_Orange
« Reply #24 on: 21 July 2009, 18:24 »
Squeak went after a week or so  :smiley:
Left now with a clutch that feels 200% better than the old setup!
Just not sure what to do with the big box full of bits left over now...  :tongue:
Build thread clicky
Offline richw911
« Reply #25 on: 21 July 2009, 18:40 »
Good work well worth it isnt it  :cool:  :wink:
Offline barry-gti
« Reply #26 on: 21 July 2009, 18:41 »
i need to do this!...maybe in a couple of months...
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #27 on: 27 July 2009, 19:47 »
take it down vag and trade it in for something else ha ha pathetic that surcharge
Offline barry-gti
« Reply #28 on: 04 August 2009, 10:41 »
i've ordered the clutch. does the release bearing come seperatly?
Offline richw911
« Reply #29 on: 04 August 2009, 17:16 »
Depends if you ordered the 3 in 1 kit or not   :smiley:
The VR6 bearing is the same as the 1.8T standard one BTW  :wink:
