Author Topic: Standard Alarm  (Read 1634 times)
Offline Ady TDI
Standard Alarm
« on: 01 August 2008, 17:41 »
Does anyone know how i can turn the sensitive on the alarm down? just had a motorbike go past and it set the alarm off  :shocked:
Offline richw911
Re: Standard Alarm
« Reply #1 on: 01 August 2008, 18:32 »
Dont think you can TBH  :undecided:
Offline Dubbz
Re: Standard Alarm
« Reply #2 on: 01 August 2008, 19:06 »
Is it true you can trun the DB up on the alarm with Vagcom??  :shocked:  :cool:
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline GTi-Matt
Re: Standard Alarm
« Reply #3 on: 01 August 2008, 19:09 »
doesnt the button on the drivers b pillar turn it on and off?? worked on mine with the chav at work with 20" exhaust setting mine off everytime he parked up!!!!! :evil: :evil: :evil:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline richw911
Re: Standard Alarm
« Reply #4 on: 01 August 2008, 19:13 »
That button turns off the ultra sonics inside the car - so you can leave dogs in the car. lol @ chavs  :grin:
Offline richw911
Re: Standard Alarm
« Reply #5 on: 01 August 2008, 19:33 »
Might be able to do it with vag com:
Try this:
Select -> 45-Int.Monitor -> Adaptation -> Channel 01.
Stored value should be 100 (for 100% sensitivity).   You should be able to reduce it to as low as 50.
Not sure if this works on golfs does on audis tho  :undecided:
Offline Ady TDI
Re: Standard Alarm
« Reply #6 on: 01 August 2008, 20:30 »
No vag.com  :cry: so cant do it
Offline vicky
Re: Standard Alarm
« Reply #7 on: 01 August 2008, 20:42 »
what is the drivers b pillar?  i need to turn the sensors off in my car, can someone please tell me how to do it
cheers
Offline richw911
Re: Standard Alarm
« Reply #8 on: 01 August 2008, 20:49 »
cheers
Bottom of the drivers door next to the piller there is a small button  :wink:
