Author Topic: Got 19" alloys coming will they fit on my gti if lowered?  (Read 3326 times)
Offline bling
I have some 19" alloys coming for my gti-mk5 this weekend, i will be using 235 x 35 tyres and the wheels are a 45mm offset and a 8" wide.
Question will the alloys fit ok with the H&R springs which drop it by 30/35mm
or shall i stick with the eibach sportline kit which drops it 20/25mm?
Offline 182_blue
which alloys are these ?
Offline gazbutmk5gti
you should be ok if you tuck the liners behind the tabs on the front, think neg has H&R springs with 19's but his are ET51, so maybe that 6mm might make difference?
Revo stg2+ & lots more
Offline neg
I reckon they'll fit fine!
Come on then what you going for... ??
Offline martininwillerby
  • Golf GTD DSG
I would be very careful. A wheel with a ET45 and 8" wide will be 12mm further out, plus the extra tyre width will take it to at least 17mm. This may even be Greater depending on your tyre choice. Even on a standard OEM set up IMO you'll get rubbing, More so when you press on a bit going around corners with the tyre wall flex.
I was told by TYREMEN of Hull that they were not prepared to sell me ET45 / 8" wheels because of this.
Martininwillerby
Golf GTD DSG, RSN510, DAB, Bluetooth, Leather, 18" Charleston Shadows, Park Assist And In The Best Colour... White.
Martininwillerby
Komenda
Mine are ET45 and 18x8.5 inches wide. Mine is very low and I have never had rubbing. They'll be fine.
  • Golf GTD DSG
READ THIS TREAD... Dave had 19" x 8" ET45 wheels with 235/35/19 tyres on this standard R32.
http://www.r32oc.com/showthread.php?t=1095
Martininwillerby
Martininwillerby
Offline Rob-MK5
You should just be ok,
H&R are a tad lower than sportlines, but then abit harder, had both springs but always had 19'' with ET50.
Rob
Offline Rosie
Hmmm, i have to say, mine is on 19's and lowered 35mm and i am having some major problems atm.
But i did mine the cheap way and now having to pay sh!tloads to sort it all.
We'r like marmite. Mmmmm, i love marmite :D
www.bebo.com/pussycat99
Offline bling
So at the moment the answer is Yes and No? :rolleyes:
Some people find they fit while others find they don't
I suppose i will have to just trust the guys i bought them from.
Thanks for all the replies, wether it has helped...not sure but at least i have some warning on what can happen.
