Author Topic: CV Boot  (Read 2265 times)
Offline Ady TDI
CV Boot
« on: 21 May 2008, 14:21 »
Had a mechanic come out to change my outer cv boot on monday, he couldn't get the metal clips on so held it on with cable ties, i looked this morning and there is grease everywhere  :sad: looks like i got to buy another cv boot and take it to a garage, more money
Offline Ashmond
  • Money, b!tches And Boost
Re: CV Boot
« Reply #1 on: 21 May 2008, 14:32 »
Alot of places cable tie them, if they dont have at least a cable tie on them its a mot fail mate
Offline Ady TDI
Re: CV Boot
« Reply #2 on: 21 May 2008, 14:57 »
It came with metal clips tho, but he couldn't get them on thats why he cable tied it, i just noticed alot of grease, will have to get under it and make sure it hasn't come off.
Offline Ashmond
Re: CV Boot
« Reply #3 on: 21 May 2008, 15:10 »
yeah there will be grease thats just for the actual cv mate, cant tell without having a butchers underneath
Offline rheady
Re: CV Boot
« Reply #4 on: 21 May 2008, 16:12 »
If there is grease everywhere then its either just come off because the cable tie has failed or it has split because it has been flapping about when you have driven it. If its the first then buy some new grease and pack it in and try and get the metal ties on it. When you take the wheel off you should be able to do this yourself. Just don't overtighten them that you cut into the gaiter.
Offline GTi-Matt
Re: CV Boot
« Reply #5 on: 21 May 2008, 18:56 »
and make sure you tighten your nuts properly afterwards!!!!!!
the wheel nuts not yours, dirty boy!!!!!! :laugh: :laugh: :laugh:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline Ady TDI
Re: CV Boot
« Reply #6 on: 21 May 2008, 19:08 »
Ha ha  :laugh: will get underneath and check it all, cheers
Offline Ady TDI
Re: CV Boot
« Reply #7 on: 22 May 2008, 18:41 »
Just been under the car and the cv boot has come of from the wheel, is there anywhere i can get the grease & clip from without buying the full kit?
Offline golfgtidan
Re: CV Boot
« Reply #8 on: 22 May 2008, 18:45 »
shame u aint bit closer to my neck of the woods, i work in a garage and we have tubs and tubs of the stuff. oh and i got good crimping pliers for c.v boot clips! hope you get it sorted :smiley:
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
Offline Ady TDI
Re: CV Boot
« Reply #9 on: 22 May 2008, 20:06 »
That's a shame  :sad: nevermind the cv kit was only £11 odd quid so no too expensive
