Author Topic: Broken Compressor  (Read 1514 times)
Offline Booky16v
  • V6 4motion and Honda CBR 1000RR Fireblade
Broken Compressor
« on: 21 May 2008, 13:48 »
Does anyone know if an AC compressor from a mk4 1.8T will be a direct swap for the broken one on my 4mo?    (AUM Engine code)
Stealers are telling me I need a 4mo specific one........or did they see me comming?
Thanks
2000/W, 204 Bhp AUE, Full Leather Recaros, Aero wipers, Santa Monicas on Eagle F1's, OEM R32/Anni rear spoiler, Climatronic, OEM 312mm powder coated calipers/carriers
Offline Booky16v
Re: Broken Compressor?
« Reply #1 on: 23 May 2008, 20:25 »
anyone?
Offline Saffa
« Reply #2 on: 23 May 2008, 23:29 »
Hi,
Will look it up tomorrow and let you know.
Jochen.
Offline caddy vantastic
« Reply #3 on: 24 May 2008, 08:38 »
The part number should be along the lines of 1J0820803L which was also fitted to four cylinder engines IE a 1.8t  :wink:
To much going on to list all the work
Offline Saffa
« Reply #4 on: 25 May 2008, 14:38 »
Upto chassis 1J Y 300000 the compressor fitted should be made by Sandem (SD 7 V16).
Part number listed - 1J0 820 805. This is also fitted to the 4 cylinder engines, but 4 cylinder engines also have a option of a zexel compressor which will not fit V6.
Chassis 1J Y 300001 onwards has the Sandem ( SD 7 V16 ) but has part number 1J0 820 803 K, this is also fitted to the 4 cylinder cars.
Hope this helps? basically as long as it is made by sandem and has the same connector it should fit?.
Jochen.
Offline gtitdi
« Reply #5 on: 25 May 2008, 17:45 »
If you can pull the sticker off the old one, the model number will be on there. Then try looking on ebay, I just got one for my TDI for £39.99! Works, too!
