Golf mk4
Wazzzer
Engine cutting out
Topic: Engine cutting out (Read 2139 times)
don-tucker
Engine cutting out
21 May 2008, 07:57 »
Every now and then my engine seems to cut for a split second,went for a long run and thought it was cured but it's back again. Any ideas please.I know it could be anything but wondered if it was a common thing.
Don
2003 Golf Mk 4 1600 16 valve
Ashmond
Money, b!tches And Boost
Re: Engine cutting out
21 May 2008, 14:35 »
battery terminals loose? air leak?
GTi-Matt
21 May 2008, 19:02 »
coil pack or senser mate
Quote from: Ivor Mk4 Turbo on 05 September 2008, 14:18
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!
richw911
10k hero
The Linkmeister and an OEM Freak.
21 May 2008, 19:14 »
Sounds to me like a split pipe TBH
boyob32
Here all the time
1.8T
21 May 2008, 19:18 »
Does anything appear on your dash....engine management light?
don-tucker
21 May 2008, 19:37 »
Thanks for the ideas,I'll try and check the dash but the trouble is it happens without warning.
Don
Krispy
Here all the time
Reply #6 on:
21 May 2008, 19:40 »
i get the same thing mate.. but i have no clue wt it is n neither do mechanics.. going to see a vw specialist next week abt it to see if he can help so ill let u know if he figures it out..
don-tucker
Reply #7 on:
22 May 2008, 07:07 »
I wondered if Vag-com would sort it out,I have installed version 409-1 and thinking of this interface
http://cgi.ebay.co.uk/USB-Diagnostic-vag-com-OBD-2-Interface-VW-AUDI-vagcom_W0QQitemZ320254761050QQihZ011QQcategoryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
,Any good??
Don
Krispy
Here all the time
Reply #8 on:
24 May 2008, 00:52 »
i already put mine on a vag com n nothin came up (if its the same problem as urs that is).
you could check ur throtlle body, maybe its dirty n thats y ur carr is cutting out
boyob32
Here all the time
1.8T
Reply #9 on:
24 May 2008, 10:35 »
I had a simular issue...while driving it would cut out and then immediately return. Very intermittant and very annoying! Mine was an issue with my ECU....
Golf mk4
Wazzzer
Engine cutting out
