Author Topic: MK3 GTi electrics  (Read 1217 times)
Offline D Squared
MK3 GTi electrics
« on: 20 May 2008, 21:29 »
Hi all, i had a few stereo problems, but to cut a long story short, i found some broken wires in the O/S/R door shut in the rubber boot. So soldered them together, go my rear speaker working now, which is good, but could not find a home for a small black and green wire...? I was wondering if this was anything to do with a couple of problems i have??
When i lock the car, 20ish seconds later it appears to try and lock itself again, with no input from me??? is this normal? ie deadlocks maybe??
Also should the rear windows switches illuminate?? with the lights on, when opening the back doors should the light left on buzzer come on?? - it doesn't on both my back doors, but does on the fronts and the boot.
Everything else appears to work, although apart from the speaker, it all did before but i found 4 broken wires, 1 of them being a thick red and yellow....strange
MK3-MK5- Now MK7 GTi
Offline VW_08
Re: MK3 GTi electrics
« Reply #1 on: 20 May 2008, 21:37 »
Firstly yes thats the deadlocks, mine does this and it also tricked me into thinking something was up  :laugh:
Secondly, the "lights on" warning will only sound if the lights are on AND the engine is turned OFF, if the engine is on then it wont work no
So the wires part you can forget because there is no problem then?
« Last Edit: 20 May 2008, 21:41 by VW_08 »
Offline D Squared
« Reply #2 on: 20 May 2008, 22:00 »
ok deadlock thing sorted - thanks
so with lights on engine off, both my front doors and hatch activate the buzzer, but both back doors don't is that normal? or is there something a miss?
what about the rear electric window switches, should they illuminate with the lights on? as the fronts do...
Offline VW_08
« Reply #3 on: 21 May 2008, 13:11 »
ive got a 3door so not too sure, even if they stopped working it will only be a simple bulb change probably if your that bothered.
About the lights on warning............ as long as the drivers door tells you your lights are on thats the main thing?
« Last Edit: 21 May 2008, 13:13 by VW_08 »
Offline Flankerharv
« Reply #4 on: 21 May 2008, 13:34 »
My buzzer for the lights doesnt work, many a time if left them on and rained the battery.  I wouldnt even know where to start looking to get it fixed.
Offline AndC
« Reply #5 on: 21 May 2008, 15:41 »
Thick Yellow, red or orange wires are often related SRS!!
Be careful with them!
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 22 May 2008, 14:32 »
I dont think you will find an SRS in the door of a MK3 :laugh:
« Last Edit: 22 May 2008, 14:38 by Rmachines »
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline beni-iow
« Reply #7 on: 22 May 2008, 21:53 »
what is srs?
Offline Rmachines
« Reply #8 on: 23 May 2008, 01:50 »
Safety Restraint System i think
