Author Topic: clicking front speaker  (Read 2167 times)
Offline eddie1905
« on: 17 May 2008, 21:08 »
I've just fitted a set of component speakers into my mk2 golf but the drivers side speaker and tweater  click most of the time  there ok sometimes but most of the time they just click  :sad:, I've checked the wires and eveything looks ok .The rca cables are run down the same side as the speaker wires could this cause the problem or has any1 got any other idea of what it may be.
Thanks for any help you can give me.
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: clicking front speaker
« Reply #1 on: 20 May 2008, 11:01 »
they are faulty. take them back and get replacements. also dont kain new speakers/tweeters when you get them
Offline JamesS
« Reply #2 on: 20 May 2008, 23:27 »
My drivers side Infinity Kappa tweater softly ticks/clicks. It came back form a service and it started :angry: for some reason. If you have the volume at 0 it ticks with the speed of the revs. If you rev the engine from idle you can hear the tweaters clicking speed up. Any idea what this could be???
Is it faulty?
Thanks in advance.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline eddie1905
« Reply #3 on: 21 May 2008, 05:58 »
I've tired them on the other side and they were fine so I tired the ones from the other side and they do the same thing when fitted in the drivers side so dont think the speakers are faulty do you think it could be the crossover/wireing thats at fault , The strange thing is that they are ok some times though thats why I thought might be a prob with the wirein ,would the quality of the rca make any diffence ?
Offline russ-vdub
« Reply #4 on: 21 May 2008, 16:14 »
Ah this is now time for an Interference supressor that bolts onto the alternator or inline with the rca leads.
RCA supressor:
http://www.m-99.co.uk/Car_Audio/Noise_Suppressor/noise_suppressor.html
Alternator supressor:
http://www.classicsagogo.co.uk/acatalog/suppressor_kit_sml.jpg
« Last Edit: 21 May 2008, 16:16 by russ-vdub »
Offline lordbigsack
« Reply #5 on: 23 May 2008, 16:05 »
To add my 2p worth, make sure the Earth is solidly mounted to bare metal on the chassis
S
Things I need (Mar 08): 1990 Drivers door in calypso green for 3door - someone must have one!
Things I have found: (Mar 08)Power steering pump bracket, sun visor clip
