Author Topic: Should i rotate tyres?  (Read 5351 times)
Offline K1
« on: 17 May 2008, 14:24 »
Hi all... just wondering do you guys rotate your tyres front to rear? I did it on my rx-8 but made the car awefully twitchy at the rear for a thousand miles or so. Would you recommend doing it on a fwd car? Cheers.
Kev
White Edition 30. Born 26th/June/2007. Highline, Xenons, IPOD+Armrest, Cruise Control. Dbilas intake, Forge short shift, GIAC fuel maps, Forge DV, Milltek Non-res Turbo back, Eibach pro damper, pro kit and anti roll bars. Black Monzas, Kenwood DNX5220BT, R32 Front n rear brakes
Offline 182_blue
Re: Should i rotate tyres?
« Reply #1 on: 17 May 2008, 14:26 »
no, i wouldnt bother, your better of having the grip at the rear anyway (i.e most tread), and all it means is you will need to replace all four tyres at the same time , IMO of course  :smiley:
Phil mcavity
« Reply #2 on: 17 May 2008, 17:34 »
so ok 182, if you have a puncture on 1 tyre on the front that couldnt be fixed, with good tread on the tyre, would you replace all 4 then to get the Handling right??, seems a very expensive method. I agree with doing 2 as long as they are on the same axel then the handling shouldnt be effected.
Rx8 is rear wheel drive, GTi is front wheel, so you wanna go rears to front 1st, and put the new rubbers on the rear.
Offline 182_blue
« Reply #3 on: 17 May 2008, 17:41 »
i must have misread what he put, but he never mentioned punctures !!, and never mentioned needing new tyres, just rotating them , i never said swop all fours in one go ??, i said rotating causes you to have to swop all four in one go, i was trying to tell him to avoid the need to swop all in one go (as they all get worn at the same rate, hence need swopping at the same time) , if were talking new tyres i would put new tyres on the rear, BEST TYRES ON THE BACK ALWAYS  :smiley:
« Last Edit: 17 May 2008, 17:56 by 182_blue »
Phil mcavity
« Reply #4 on: 17 May 2008, 18:58 »
thing is, unless im missing something, front wheel drive cars go through roughly 2 sets on the front to one pair on the rears, unless the tyre has perished or shows signs of stress on the tyre walls. Surely, the fronts are the most important as the have to contend with steering, horsepower, and the rears dont have as much to contend with and will last twice as long (on average) then the fronts ( talking normal driving Perameters).
Offline 182_blue
« Reply #5 on: 17 May 2008, 18:59 »
Well IMO always have the best tyres on the back
Offline Hurdy
« Reply #6 on: 17 May 2008, 20:53 »
I've never rotated my tyres. Never had any issues with handling or grip either apart from when they are near the end of their lifespan anyway.
Seat Leon Cupra Black 290 DSG
Offline Spaced
« Reply #7 on: 17 May 2008, 21:19 »
I would also keep the best ones on the back.
BTW if you keep a balanced throttle though the bends, like a good racing driver then all 4 tires should wear evenly  :wink:
Loyal owner since 2005, done with remapping, I drive a Golf not a Veyron. (hypocrite)
Offline RedRobin
« Reply #8 on: 17 May 2008, 23:15 »
....I think we all know that tyres MUST be kept paired to the axle.
Because I need only 2 new tyres and I want the new Goodyear F1 Assymetrics, I recently had a chat with Goodyear's UK techsupport (very helpful and very friendly) and they strongly advised me to keep the deeper treads on the rear axle for a FWD car and that it was alright for me to mix the new Assymetrics with their Eagle F1's (which I currently have). But with a 4WD car such as the R32 you should change all 4 at once and not mix them.
Offline 182_blue
« Reply #9 on: 18 May 2008, 06:20 »
are you on 18's ?, i got quite a good deal on a set of F1 asymetrics
