Author Topic: ABS Light question  (Read 953 times)
Offline madmanmavis
ABS Light question
« on: 16 May 2008, 09:07 »
Hi guys
I realised the abs light on my golf had been disconnected because when turn ignition on nothing showed
Had a little play yesterday and plugged all back together and hey presto light came on and stayed on.
But the handbrake light also came on and stayed on? is this related to the abs? or another problem?
Im hoping its just the sensors and nothing else.
Offline Pete Taylor
Re: ABS Light question
« Reply #1 on: 16 May 2008, 14:13 »
Handbrake warning light will stay on constant with the ABS light to show multiple faults with the system, probably both rear sensors gone
Offline monkeyalan
« Reply #2 on: 16 May 2008, 16:26 »
what Pete said, my mk3 fronts both went and the handbrake light stayed on til i fixed them.
Offline mush
« Reply #3 on: 16 May 2008, 17:19 »
might have been disconnected for the mot or something..its easley missed by a numpty mot station..
try this
mines still not come back on been x2 weeks now  :smiley:
click ere
http://www.golfgtiforum.co.uk/index.php?topic=85171.0
if it stays on like pete said could be your sensors
« Last Edit: 16 May 2008, 17:26 by mush »
MK2 golf 16v :-)
Offline mark3valver
« Reply #4 on: 16 May 2008, 18:31 »
vag com will tell you what sensors are not giving a signal. can be picked up cheap enough and fitted easily... there is a guide on here i believe
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline madmanmavis
« Reply #5 on: 19 May 2008, 09:10 »
Yeah i figured a sensor or two hopefully anyway! Guess i need to get it checked via vagcom to see which ones need replacing. Just wanted to make sure the handbrake wasnt goosed as well
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 19 May 2008, 12:50 »
