Author Topic: Golf noob questions...  (Read 1711 times)
Offline BaldyBastard
  • Project Darkee in killed :-(
« on: 26 April 2004, 00:52 »
Evening Folks...
Just aquired myself a little run around to get me about cheaply...
MK2 Golf CL 1.6 - F reg with 81k on the clock.
I'm wanting to draw on some of the speciality knowledge here  ;D and hopefully have a couple of questions answered.
1. It looks like there is oil in the air filter box.  Whats causing this and is it anything to worry about ?
2. The brakes feel as though they don't have a servo, ie it takes a bit of a heavy foot to stop (I'm getting used to this), but is it easy enough to just fit one from a higher spec'd model ?
3. On turning the ignition (just the first turn, not actually starting the car) there are a couple of lights flash on the dash, namely the water temp and oil, after a couple of seconds the water temp stops. The oil light continues to flash until I start the engine then it goes off..   Is this OK ??? I've checked the oil levels and they seem fine.
« Last Edit: 26 April 2004, 01:13 by BaldyBastard »
- The liver is EVIL and MUST be punished -
** breaking a Black MK2 Driver (H reg) - PM if you need any bits **
Blue MK2
Re:Golf noob questions...
« Reply #1 on: 26 April 2004, 05:21 »
think thats about right as mine does something like that
Offline MK4_20VT
« Reply #2 on: 26 April 2004, 13:48 »
1. This can be a result of along time between oil changes (the oil could be cack)
3.  As far as I know the oil light will stay on until you start the car because there will be no oil pressure, until the engine is running
hope this helps
