Author Topic: its broken  (Read 1249 times)
Offline squires
its broken
« on: 12 May 2008, 19:18 »
i have a mk2 89 reg golf gti 8v, and have been having problems with it, when im driving it sometimes starts missfiring so bad tht if i put my foot on the pedal full down it will jus miss an backfire, and a very loud whining noise comes from the back, if i tutn it off and leave it for a abit it clears up then it all happens again.
i suspect its the main fuel pump or lift pum but has anyone had any similar problems or better ideas?
i have changed the dizzy cap an rotor arm and plugs, i dout its electrical as the whining noise only starts when it breaks down thn goes when its all cleared up.
any help much appreciated as iv only had the car 1 month now and only used to classic minis lol
cheers lee
Offline squires
Re: its broken
« Reply #1 on: 12 May 2008, 19:19 »
forgot to add it also takes about 10 seconds to start of the starter since it started playin up
Offline Jay
  • balding fat cvnt
Re: its broken
« Reply #2 on: 12 May 2008, 19:22 »
It could well be a fuel pump issue by the sounds of it, but more importantly MK2's are taking over the classic mini world  :evil:
Offline squires
Re: its broken
« Reply #3 on: 13 May 2008, 14:03 »
well i sold mine for one, woud of got one in the first place but needed to get a years no claims first as i was 19 to. jus gotta figure which pump now
Offline Simeon
Re: its broken
« Reply #4 on: 14 May 2008, 13:14 »
Disconnect the main pump either by removing the fuse or pulling the plug out of it and turn the ignition on - should be able to hear the lift pump prime up. If not, replace it - easy job and much cheaper than the main pump.
Offline squires
Re: its broken
« Reply #5 on: 16 May 2008, 18:02 »
iv found out if i keep it above a 1/4 of a tank its fine so its deffo the lift pump, havin trouble loggin on to this site taken me 2 days, norm comes up with page not displayed :angry:
