Author Topic: All digi ECU's compatible?  (Read 1064 times)
Offline cняis
« on: 12 May 2008, 16:13 »
So i have a project car that refuses to start, and a daily which (ignition wise) is 100%.
Project is an early 89 Digi with the earlier wiring (hazard switch on dash)
Daily in a late 90 digi with later wiring (hazard switch on column)
project has a seimens ECU
daily has a bosch ECU
is it OK to try the daily's ECU on the project to rule the ECU/ignition module out? will it work?
Offline cняis
Re: All digi ECU's compatible?
« Reply #1 on: 13 May 2008, 09:10 »
someone must know?  :sad:
Offline Mew
« Reply #2 on: 13 May 2008, 09:51 »
I think they're all compatible, at least i'm pretty sure that is what i was told a while back. Don't blame me if it all goes wrong though!
Offline cняis
« Reply #3 on: 13 May 2008, 09:54 »
i dont fancy being without 2 cars thanks  :tongue:
i need to know for definite really, i was told a while back that bosch make stuff for seimens (or vice versa) so they should work, but unless someone is 100% im not going to try it.  :undecided:
Offline Mew
Offline cняis
« Reply #5 on: 13 May 2008, 10:12 »
http://www.golfgtiforum.co.uk/index.php?topic=33189.0
http://www.golfgtiforum.co.uk/index.php?topic=71238.0
They're the answers i get with a search  :wink:
thanks a lot smarty pants!  :lipsrsealed: :tongue:
i will be busy tonight then
