Author Topic: Opening of front windows via key fob  (Read 2724 times)
WhiteGTI
« on: 12 May 2008, 06:19 »
When I do this by holding down the unlock / lock button respectively, only the drivers window goes down / up...  i swear when I first did this when I got the car that both windows would sync together.
What do your windows do?!
Thanks all. Chris.
Offline 182_blue
Re: Opening of front windows via key fob
« Reply #1 on: 12 May 2008, 06:31 »
hmm, didnt know you could make the windows open by pressing the key button ?, but when i press lock all windows and sunroof close together
Offline RedRobin
« Reply #2 on: 12 May 2008, 07:19 »
....All my windows open (5-door GTI) with my remote keyfob. :cool:
NewGolf
« Reply #3 on: 12 May 2008, 07:52 »
I can open all my windows with the "open door" button if I hold it down long enough, and close all the windows by holding down the "lock door button", and again holding it down.
You can turn this on with VagCom, I think its under "convenience module" or similar.
Offline neg
« Reply #4 on: 12 May 2008, 09:07 »
Shuts the roof after the windows too if you have a sunny, doesnt open it though.
Offline SteveS
  • GTI ED30
« Reply #5 on: 12 May 2008, 09:13 »
u need to conf the pass window.
open the window so its all the way down, release button then push  down again for a few seconds... then hold the button up so the window shuts. then hold the button up for a few seconds. now the window should auto go all the way up or down when you push the button all the way up or down or key.
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline maxamus
« Reply #6 on: 12 May 2008, 10:34 »
both my windows open and shut via keyfob  :wink:
looks well cool
Offline 182_blue
« Reply #7 on: 12 May 2008, 12:19 »
something i didnt even know the car did again :-)  , will try it later
WhiteGTI
« Reply #8 on: 12 May 2008, 19:06 »
Just tried that, and it didn't work! Thanks anyway mate.
Offline AlanD
  • MK5 2.0T 16v
« Reply #9 on: 12 May 2008, 19:13 »
I tried this today and it works on mine, hold down the unlock button when unlocking the car and the windows go down, not tried the hold down lock and windows go up, pretty good idea and quite handy, especially with this heat we have the moment :)
