Author Topic: Need help pretty fast.. about to start the job :]  (Read 1635 times)
Offline Seansixx
hii new here.
i bought a 1.8 golf gti recently and need to change the front pads.. however the pads i bought are different shapes/sizes. one of them is a long thing pad and the other is a fatter one.
i dont spose anyone would happen to know which pad is on the outside of the disc and which is on the inside would they?
thx for any help
Offline odub
Re: Need help pretty fast.. about to start the job :]
« Reply #1 on: 09 May 2008, 18:02 »
they should be the same. think your new pads are duffers
60 percent of the time it works EVERY time
Offline Jay
  • balding fat cvnt
« Reply #2 on: 09 May 2008, 18:05 »
They should be 14mm thick on the front and the same size I think.
Offline Seansixx
« Reply #3 on: 09 May 2008, 18:15 »
hmm i bought them from euro car parts.. gave them the number plate and they told me they were the ones.. one of the pads is longer and thinner.. and one is wider
thats what they look like. If they are the wrong ones ill just have to go back tomorrow and change them then.. urgh never get anything done :P
guess i could have stood still while taking the pic  :grin:
Offline Khare
  • The bear that khares
« Reply #4 on: 09 May 2008, 18:38 »
there ok. the thinner one, should be the smaller one (verify this) and the thinner one goes on the inside of the disc. the long fatter one goes on the outside.
correct me if im wrong.
Offline daniel-1986
« Reply #5 on: 09 May 2008, 18:45 »
i think the fatter one goes on the inside as it gets more pressure from the piston when pressing the brakes but could be wrong as i helped my mate change the pads on his mk2 golf 1.6 driver about 6 months ago
Offline Jay
  • balding fat cvnt
« Reply #6 on: 09 May 2008, 18:49 »
I had a look in my Haynes manual and couldn't see anything about them being different.
Maybe they are the correct ones, phone up GSF and say you bought a set from them and ask if they are meant to be like that  :smiley:
Offline Seansixx
« Reply #7 on: 09 May 2008, 19:04 »
they are Guttmann pads if that means anything to anyone.. ive never seen them before
Offline fused
« Reply #8 on: 09 May 2008, 19:59 »
The gti pads I had, they are different inside and outside, the way to check is whip the old ones off  :wink:
I'm sure the wider ones go on the piston side, the others wont sit properly.
have fun, don't round the ally key bolts off! I'd buy some new ones to go back in, if I was you!
Offline Seansixx
« Reply #9 on: 09 May 2008, 20:16 »
ok thanks will try them that way then.. im going to do it tomorrow instead.. i decided im too lazy :P
yeh they were rounded off before i took them out.. had to take the disk off brake disc off to get it out. bought 2 incase the other side is fooked aswell.
if i can get it done tomorrow it "should" be road worthy :D
only paid £150 for it with a bent wishbone.. replacement came with it and i replaced that in a couple of hours.
not bad for a superchipped,remapped gti will a full custom £250 exhaust system.. cant wait to get it going  :grin:
