Author Topic: Manifold Advice Needed  (Read 1699 times)
Offline Kent
« on: 09 May 2008, 16:59 »
I have just purchased an Ashley Competition manifold and full exhaust system and require some advice on the fitting of the manifold.
A friend of the family is fitting this through this fathers garage, he has advised me that to fit the manifold he will have to remove the injector rail/fuel pipes and drop the engine to enable him to get to the manifold.
The questions I need answering are:-
1)   Will you have to remove the injector rail/ fuel pipes?
2)   How long will it take to complete the job?
3)   How much should it cost to complete the fitting of the manifold and exhaust system?
I would really appreciate your advice on this guys.
Cheers. :huh:
Offline Dolly
Re: Manifold Advice Needed
« Reply #1 on: 09 May 2008, 19:12 »
to be honest the easiest way ive found is take the engine out. sounds extreme but i have some very rusty nuts and studs and it would been near impossible to do in situ, just so happened i was swopping engines at the time lol
Offline Kent
« Reply #2 on: 09 May 2008, 19:46 »
A big job then!!! :shocked:
Offline fused
« Reply #3 on: 09 May 2008, 20:03 »
yeah put mine on when engine out....
there is a reason why VW put a break in the down pipe!!
it can't go in from the bottom due to the steering rack clearance, so that means in from the top. go and take a look.... there isn't a lot of room!
probably need to take the inlet off aswell to be honest, so yeah, not a quick fix. BUT well worth it  :grin:
Offline Kent
« Reply #4 on: 09 May 2008, 20:24 »
How long do you think it would take? and what would you expect to pay?
Offline Kent
« Reply #5 on: 11 May 2008, 11:51 »
I have been quoted between £100 and £150 to complete the job.
Does this sound right? Does any one in the Midlands know of anyone decent who would be able to do this for me.
Offline wrexham mk2
« Reply #6 on: 11 May 2008, 12:01 »
 Had mine fitted at demon tweeks, took them 4 hours  :shocked: :shocked:
Wasnt cheep either!!  :angry:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #7 on: 11 May 2008, 12:24 »
A friend of mine had a tubular manifold fitted to his MKII jetta 16v. They had to drop the subframe. I would spend the £150 and forget about it. At least it will be on without you having the trouble of doing it. And it will come with a labour warranty. :smiley:
Offline Kent
« Reply #8 on: 11 May 2008, 12:50 »
The only worry I have is that the manifold is not a stainless one its a Ashley Comp Manifold although I have been advised that it will give a good BHP increase and sound quality I don’t know how long its going to last.
I'm thinking that i should have gone for a stainless manifold as it would have lasted longer.
Ashley - http://www.ashleycompetitionexhausts.com/ashleyframeset1.html
Offline Mew
« Reply #9 on: 11 May 2008, 13:34 »
Ashley manifolds don't have the best reputation for quality and fit  :huh:
