Author Topic: brakes firmer with weight in the back.....bleeding agin?  (Read 938 times)
Offline boneybradley
  • Back in a Mk3...
Right my current issue is with my brakes...basically they are fine with a progressive pedal when its unloaded but add weight in the back and the brakes are much higher up the pedal and feel more spongy.. could this be another bleeding problem as i had fun last year with trapped air in the rear calipers! I know there is the load valve out back but does this need something doing to it when bleeding? It was pressue bled but we didnt do anything with this valve...
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: brakes firmer with weight in the back.....bleeding agin?
« Reply #1 on: 07 May 2008, 16:06 »
sounds like something to do with the brake balencing valve on the rear beam might have air in the system but the load is effecting this valve?!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Blackie_No1
  • GTi baby!! woop woop!!
« Reply #2 on: 07 May 2008, 16:31 »
Is the car lowered, this can make a difference with a load in the back as the load valve is then confused.
Usually you would notice that the rear locks up more than it would have before it was lowered as the valve puts more brake bias to the rear as it thinks there is a load in the back.  Maybe if it goes lower than this when a car is lowered and has a load ion the back the system may not be able to cope?
'97 8v GTi, Piper S/Steel Zorst, K&N panel Filter, Jamex 40/35 kit & Gas shocks
Offline Pete Taylor
« Reply #3 on: 08 May 2008, 09:51 »
do the 8v mk3s have rear balancing valves??
16v and VR6 is electronically controlled through the ABS I thought?
Offline adyh
« Reply #4 on: 08 May 2008, 13:52 »
Not all Mk3's came with ABS , notABS then you have the balancing valve
  • Back in a Mk3...
« Reply #5 on: 08 May 2008, 18:31 »
mine has abs and a valve thats next to the axle  (where the bush is on the passenger side) that looks very like a load valve and it does push against the axle by some sort of rod thing?
