early digi was kjet
WTF?
You goon - they're two totally different injection systems - K-Jet = mechanical, Digifant = electronic.
87 *should* be digifant.
All G2 16V motors run on K-Jet.
Oh and 16V gearboxes have a larger input shaft and run a bigger clutch.
This means you'll need the pressure pump from a 16V as well as the motor and really you'll need the 256mm front brakes and 22mm master cylinder from the 16V to make sure it stops. oh that's after you've either fitted the weaker 8V clutch on your (weaker) 8V gearbox... which will have ratios not designed to work with the 16V motor.
Go find a Toledo 16V and drop the front subframe, taking the engine and box out - fit the lot and have an ABF with 280mm front brakes, a cable-change box et al.
