Author Topic: ABF power-up! How?  (Read 2215 times)
Offline Neza
ABF power-up! How?
« on: 01 May 2008, 11:52 »
Hello! Can you help me, with solution how to power up my Golf 3 GTI 16v (ABF engine).i have already installed a cold air intake, supersprint exhaust.
is there any solutions with ECU?
maybe chip-tuning? is it works?
have you a clean exaples that chip tuning for ABF is gaved a few horse power?
where i can order it?
Offline Len
Re: ABF power-up! How?
« Reply #1 on: 01 May 2008, 12:35 »
The DIY chips off ebay are not worth buying (Blitzchip/Powerchip)
You need to go somewhere like AMD or Stealth to get a remap/chip. This should give you up to 175bhp approx
www.sas.org.uk
www.the-ace.org.uk
Offline Pete Taylor
« Reply #2 on: 01 May 2008, 13:47 »
Even Vince couldn't manage 175bhp!
There isn't much more you can do to the valver to get real gains apart from the boosted route. Ported and polished head is pointless as the ABF is a good flowing head as standard
Offline Len
« Reply #3 on: 01 May 2008, 14:04 »
Some peeps on here have had those results!
www.sas.org.uk
www.the-ace.org.uk
Offline mark3valver
« Reply #4 on: 01 May 2008, 14:07 »
175bhp from an exhaust and a remap?? crikey thats good...
i would be happy if mine did that!!!
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline VW_08
« Reply #5 on: 01 May 2008, 14:22 »
why not? 150brake out of the box........
Offline mark3valver
« Reply #6 on: 01 May 2008, 16:13 »
well an exhaust adds no more than 5, so that's 20 from a remap from a N/A engine?
although a lot of valver's produce more than standard once they get to 100k and are run in a bit....
 :wink:
Offline ollie6n
  • Spartan Lowrider!
« Reply #7 on: 01 May 2008, 17:07 »
CAMS get a set of cams, that should put a rocket up your rooster  :laugh:
Offline Pete Taylor
« Reply #8 on: 01 May 2008, 17:12 »
cams are also pretty useless on the ABF unless you have the rest setup to match
Offline mark3valver
« Reply #9 on: 01 May 2008, 18:21 »
agreed - cams don't do a lot - it already produces its power very high up (essentially a higher lift cam only really changes where in the rev range an engine will make its power, doesn't really add power)
Once I have sorted the handling etc, my list of things to get engine wise will be
New manifold
full stainless
K and N panel filter in standard box
remap
lightened and balanced flywheel
balanced crank
possible management change
