Author Topic: Waste Gate Worry  (Read 2843 times)
Offline GIT
Waste Gate Worry
« on: 30 April 2008, 00:22 »
Hav a '05 gti, you all know the sound of the turbo components when the car is building pressure and when you clutch it around 3k rpm the wastegate releases its pressure (wooush) sound, my one is suddenly very loud wooush when building up pressure and hardly any release (clutch) sound, any body have this issue before?? I got a software upgrade about 2 weeks ago but this thing only came on 2 days ago, overnight ... cheers for any advice..
Offline bling
Re: Waste Gate Worry
« Reply #1 on: 30 April 2008, 10:48 »
I had this whoosh noise and i was sure that the standard valve did not make that.
It was a split divertor Valve or more commonly known as the dump valve.
you should get it checked, on the vw VAS system it should show an error code 'turbo boost pressure exceeded low limit'
Offline joesgti
« Reply #2 on: 30 April 2008, 11:15 »
im glad i changed mine for the forge dv now as this seems to be happening alot more gti's now!!  :shocked:
GTI MK5
Not the only GTI...........but the best! ; )
Offline Hurdy
« Reply #3 on: 30 April 2008, 14:36 »
Yeah, from GIT's description it sounds just like yours did at the RR Joe.
Seat Leon Cupra Black 290 DSG
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 30 April 2008, 14:44 »
History repeating itself, we were having exactly the same problems with the mk4 years ago. A cheapo fix in those days was to use a standard item from the S3, although I'm not sure that the current S3 dv is any tougher than the GTI ones these days.
edit: actually i seem to recall having a conversation with teutonic tamer on here about this issue, might be worth digging up with the search button.
« Last Edit: 30 April 2008, 14:47 by topher »
Offline winrya
« Reply #5 on: 30 April 2008, 14:49 »
Is this with the window open??
Offline joesgti
« Reply #6 on: 30 April 2008, 14:49 »
where the hell has TT been for like 6months???  :huh:
GTI MK5
Offline GIT
« Reply #7 on: 02 May 2008, 12:18 »
Window up or down, its loud enough to hear over low volume radio noise.. Have it booked in for a check up next thursday, if I need 2 replace the valve should I get an uprated aftermarket one?? If so what is the best make??
Offline Hurdy
« Reply #8 on: 02 May 2008, 14:07 »
A Forge DV is the one most go for.
Offline GIT
« Reply #9 on: 02 May 2008, 16:04 »
Forge DV.. Does this make a louder release noise than standard?? Any benefits from this part??
