Author Topic: My life sucks  (Read 1500 times)
Offline gti south
My life sucks
« on: 26 April 2008, 17:10 »
im depressed... girlfriend of 4 years left me ...that isnt the worse thing ... driving up to hull to watch palace v hull and driving along on m11 my fan belt snaps look at the dash temp is high and battery light on by the time ive had a think white smoke comes out and the head is blown 35mm has been skimmed already.... i have two golfs the one im talking about with kent cam and a norm gti which someone crashed into the rear quater and bent the pillar slightly... would putting the engine in the busted head one b better or trying to fix it.... any help appreciated also someone mentioned i could of warped the cam?? my life is getting better  :shocked:
« Last Edit: 26 April 2008, 18:12 by gti south »
Gti 8v not bad for a first car
Offline Mid_life_crisis
Re: My life sucks
« Reply #1 on: 26 April 2008, 17:33 »
plenty more fish in the sea m8
Offline DarnPB
  • Formerly Darnpistonbroke
Re: My life sucks
« Reply #2 on: 26 April 2008, 22:35 »
Bad luck on the GF front. Know how you feel. Its 'orrible.
Back to the car. Do the engine swap to get you back on the road, then assess the cam in the damaged engine by doing a run out check on it. I very much doubt it is bent, but if it is bent, it will not rotate once its fitted to the decent head.
sharpie
Re: My life sucks
« Reply #3 on: 27 April 2008, 00:11 »
try a relationship forum tbh.
Offline Diamond Hell
  • Opinions я Us
Re: My life sucks
« Reply #4 on: 27 April 2008, 09:45 »
@ Sharpie - You Scotsmen, you're all heart, aren't you?
My advice is give up watching football - it's clearly diverting you from real issues, such as looking after your car, or your woman.
Once you've kicked that nasty little habit you'll have a much better life - not only will you be able to get to meet up with women as your car won't break down, but you'll have Saturdays free to spend taking care of any new girl, or working on your car, which will mark you out as a real man and make you far more interesting to the right sort of women.
You know it makes sense.
It's not just mechanical problems I'm here to help with.  :smug:
Offline Jay
  • balding fat cvnt
Re: My life sucks
« Reply #5 on: 27 April 2008, 10:03 »
Sorry to hear about the Golf   :sad: and your GF, hope it wasn't a nasty split.
He has a sense of humour !  :laugh:
Offline ReDBull
Re: My life sucks
« Reply #6 on: 27 April 2008, 15:38 »
On the bright side if you didn't get to the match you missed Palace lose with two mins to go.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline Agreeable Slick
  • Unit
Re: My life sucks
« Reply #7 on: 27 April 2008, 19:59 »
I feel sorry for the next poor bugger that has to use it if it was.  :lipsrsealed:
Offline gti south
Re: My life sucks
« Reply #8 on: 28 April 2008, 16:24 »
lol yeah im glad i didnt make it to hull. na wernt that much of a nasty split  :wink: anyway bk to the car is there a possibility that if i swap the engines over and then put the cam in it would be alrite the engine i would swap over is a bit tapperty thou until warm up....... and could someone tell me the code for the lil white clips that holds on the side trim managed to knock it off the car while pushing it behind the other one. then snapped a couple trying to put it bk on while angry. swapping over the engine im gussing that the only real cost would be labour in a garage ? or would they need new things? i would of attempted it myself but im moving in with my bruv and there isnt really any were to store it.
