Author Topic: 16 valve handling...all over the place!?  (Read 2898 times)
Offline devere
« on: 25 April 2008, 20:12 »
Hi.
I was hoping to get some advice on my 16v. The handling just doesnt seem right. Everytime i go round a corner, the back end just feels so 'loose'. I just wants to slide out and feels like its going to spin me.  Its as if when i go over any slight bumps, it throws the car out, and just doesnt want to stay true.  Its not too bad in a staight line,  but with the cornering problems, i just dont have the confidence in it.
I rolled my 8 valve about a month ago which seemed to be suffering from similar symptom, but it didnt feel as bad as this new one. With the 8 valve the back end over took me round a corner and i flipped afer hitting a back..     I want to be able to drive my 16v enthusiastically, but only when im happy with it.  Could the shocks be worn and old that they just arent giving the back end he grip it needs...??
Any help would be great please!
Offline boneybradley
  • Back in a Mk3...
Re: 16 valve handling...all over the place!?
« Reply #1 on: 25 April 2008, 20:17 »
I would check the rear axle bushes first....common fault but they normally come with a knock!!
« Reply #2 on: 25 April 2008, 21:42 »
Are the rear axle bushes easy to do.
  • Back in a Mk3...
« Reply #3 on: 25 April 2008, 21:45 »
it's a matter of droping the back axle off and cutting the old bushes out and then pressing the new one's in.....fairly simple with good tools but the passenger side one has the load valve in the way!!  I would never fit them again unless they were easy to fit poly bushes....
Offline devere
« Reply #4 on: 25 April 2008, 22:17 »
Is that likely to cause the back end to 'wnder' then?
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #5 on: 25 April 2008, 22:42 »
I'd check you're right foot, you sure you not just expecting a wee bit too much of your golf  :smiley:
oh.... it is a Mk3 of course :lipsrsealed: yep deffo the above  :laugh:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline Pete Taylor
« Reply #6 on: 26 April 2008, 15:25 »
To be fair it's a combination or worn axle bushes and pants standard suspension. Poly bushes highly recommended to replace the rear axle bushes
« Reply #7 on: 26 April 2008, 15:43 »
Do the poly bushes make a big difference and is it harsh with them fitted.
Offline Pete Taylor
« Reply #8 on: 26 April 2008, 16:15 »
Yes the rear end will be a lot firmer, but that's a good thing, huge difference round corners
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #9 on: 26 April 2008, 21:45 »
Mine has started to do this a little bit but the bushes are ok.  Im wondering if the suspension top mounts could be leting the shocks swing a little bit.  not sure though  :undecided:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
