Author Topic: 16 valve handling...all over the place!?  (Read 2901 times)
Offline mark3valver
Re: 16 valve handling...all over the place!?
« Reply #20 on: 01 May 2008, 14:12 »
getting all the bushes done plus a sorted suspension set up will give you loads more grip - but will probably make it less progressive when you go past that level of grip.
I tend to trail the brakes when going into corner's to try and get the front turning in nicely but you have to be really careful that the back doesn't start trying to overtake as has happened a couple of times with me, ending up facing the wrong way on a roundabout  :smiley:
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline al_bey
« Reply #21 on: 01 May 2008, 17:58 »
To be honest, the only thing ive ever experienced from my golf is under steer. Surely this is a lot more common than the back overtaking you, unless its wet or something??
Offline mark3valver
« Reply #22 on: 01 May 2008, 18:16 »
if you trail the brakes on the way into corners it can help the front turn (light braking obv!) as it will be slowing on a tighter line than the  back, it will try to come round if you hit a bump or brake to hard whilst turning in etc....
if you heel/toe you can really get a mk3 going quite nicely
Offline Greg
« Reply #23 on: 02 May 2008, 09:13 »
Trail braking's a bit risky on public roads imho  :laugh:
Mk3 pedals are at good heights for H/T though
'99 Mk4 1.8T - FMC007p - R-Tech Stage 1 | '97 Mk3 16v | '91 Mk2 16v | '83 Mk1 L
http://blackgolfgti.blogspot.com
Offline mark3valver
« Reply #24 on: 02 May 2008, 15:18 »
yeah fair point..... only drive my golf on track now (well will do one day!!!)
there is no trailing the brakes in my vectra I can tell you!!! sh!ttest chassis ever, hand at ten to two and smile when you get round the corner!!!! lol
you know those black and white chevron signs with special speed limits on in national speed limit roads that try to get you to take a harmless corner at about 30...... they are put out especially for vectra drivers
