Author Topic: IGNITION TIMING re:timing gun. come on help me  (Read 794 times)
Offline dubmad
  • dubs all the way
« on: 24 April 2008, 15:45 »
Can anyone tell me what the timing data for my 94 golf gti is, its in the manual but i dont have one yet.  :sad:Also what is the rpm timing. Do i need to leave the vacuum pipe connected or un -connected. My timing gun has 0-60 degrees on it what do i need to set it at to get the correct timing for my car. This is the first time i have used a timing gun i have always done it by listening to the sound of the engine.
« Last Edit: 24 April 2008, 18:43 by dubmad »
http://
Offline dubmad
  • dubs all the way
Re: IGNITION TIMING re:timing gun. come on help me
« Reply #1 on: 24 April 2008, 19:04 »
come on someone got to be able to help me.please help :sad:
http://
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 24 April 2008, 19:37 »
Ok..
You want 6 Degrees +/-1  at 2250 RPM
you must disconect the crank case breather hose from the pressure control valve and seal intake hose.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline dubmad
  • dubs all the way
« Reply #3 on: 25 April 2008, 10:01 »
  6 Degrees on gun yeah .but wat does this mean  +/-1 :huh:  sorry not much good with things like this but can change a engine blind folded :smiley:
http://
Offline bored_Welsh_lad
« Reply #4 on: 25 April 2008, 11:23 »
I think its reference to the advance of the distributor. +/- makes reference to the range it can be out if i remember correct...
so you can be + or - 1 degree
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
