Author Topic: Lowering ..  (Read 788 times)
Offline golfvirgin
Lowering ..
« on: 18 April 2008, 21:09 »
whats it all about ? i need my suspension sortin out , so is it a case of just tellin them " oi , while your puttin my new suspension in , lower it "   Ã‚¿? or not....
Offline VW_08
Re: Lowering ..
« Reply #1 on: 18 April 2008, 21:30 »
Two types of springs, one standard which is obviously standard height, cannot be adjusted in anyway so you cant lower it.
Or get some aftermarket ones like GMAX/KONI or like me Bilstein(pay abit more but there one of the best makers), and you choose what drop you want i.e 20mm/40mm/60mm or whatever, fit them and bam its lowered, but normally takes a few days to settle down.
If you want adjustable ones you can get them but they cost more obviously(also known as coilovers)
Hope that helps
P.s if you get lowering springs try to get the full kit with shocks aswell, otherwise if you only have the springs it will wear out the standard shocks much quicker due to the stiffer springs
« Last Edit: 18 April 2008, 21:34 by VW_08 »
Offline golfvirgin
Re: Lowering ..
« Reply #2 on: 18 April 2008, 21:44 »
cheers fella , how do you choose the drop ??  :laugh:
Offline boneybradley
  • Back in a Mk3...
Re: Lowering ..
« Reply #3 on: 18 April 2008, 21:50 »
use this guide for info....http://www.golfgtiforum.co.uk/index.php?topic=68845.0 and mine is at 40mm all round in the pictures and the front is a little too high. but i have got coilovers ready to be fitted  :cool:
Offline VW_08
Re: Lowering ..
« Reply #4 on: 18 April 2008, 22:04 »
Boney looks fine in the pics?  :wink:
not sure what drop mine is on the Bilsteins but the front is slightly lower than the back, sits fine though  :smiley:
EDIT, thats a good guide there that should help him more  :smiley:
« Last Edit: 18 April 2008, 22:08 by VW_08 »
