Author Topic: ABS rear speed sensor  (Read 1800 times)
Offline gtiscott
« on: 16 April 2008, 23:32 »
need to replace the right rear speed sensor but have a couple of questions...
1. on eurocar parts website there are a few options varying in price from £10-£50, which one do i need?
2. i have changed the front one before, is this one just the same procedure?
cheers
Scott
P.S its for a '97 16v gti
« Last Edit: 17 April 2008, 11:26 by gtiscott »
Offline mark3valver
Re: ABS rear speed sensor
« Reply #1 on: 17 April 2008, 11:47 »
I just paid £16 for a front one at GSF, best to go in and ask them for your make and model etc.
Rear works exactly the same but is harder to get out due to access.... I would remove the rear disc if you know how makes it so much easier
want a pair of raceland buckets with model specific subframes for £150 delivered? go here
http://www.golfgtiforum.co.uk/index.php?topic=83910.0
Offline 95gtipete
« Reply #2 on: 17 April 2008, 11:51 »
I would recommend ebay. There is a chap i have bought parts from who has never let me down. Front sensor each £7 all in £12 with postage.
Offline mark3valver
« Reply #3 on: 17 April 2008, 12:29 »
to save £2??? I would rather go to GSF and see the part and buy it
Offline Vdubbster
« Reply #4 on: 18 April 2008, 02:04 »
http://www.clubgti.com/forum/showthread.php?t=126595
Part number for rear off side sensor form ECP - 417440011 £11.88 in total
Did the job fine
Offline Mikester
  • Civic Type R
« Reply #5 on: 18 April 2008, 11:28 »
Hammer and screw driver tends to get mine out real good  :laugh:
Offline mark3valver
« Reply #6 on: 18 April 2008, 14:13 »
yeah the best technique seems to be aim a flat blade roughly in the direction of the sensor and smack like f**k till its in 50 bits and there is a nice hole waiting for the new one lol
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 18 April 2008, 18:12 »
and to fit use this guide....mainly covers front but includes some rear sensor details http://www.golfgtiforum.co.uk/index.php?topic=57396.0
Offline Pete Taylor
« Reply #8 on: 18 April 2008, 23:17 »
There's a lot of guides about for mk3 abs sensor removal but they're all a bit of an effort..
This is the way I do them..
When you have the sensor retaining bolt out, poke a screwdriver through one of the wheel bolt holes in the hub (one of the square ended screwdrivers that a ratchet head fits onto) and if you spin the hub around (car jacked up in gear with handbrake off) then you can feel the ABS sensor in there! Swift knock of a hammer and it's out! No breaking bits up, no removing calipers or discs and takes half the time
Offline gtiscott
« Reply #9 on: 19 April 2008, 08:35 »
cheers pete, will give it a go :smiley:,  where is the best place to put the trolley jack to give maximumspace to work in?
« Last Edit: 19 April 2008, 08:38 by gtiscott »
