Author Topic: Vag com - Hall sender (G40)?!"£$  (Read 2145 times)
Offline difficultrogue
« on: 16 April 2008, 18:39 »
Just stuck the vag com on me mates new golf and its coming back with fault 0203 - Hall sender - G40
Anyone got any ideas? :shocked:
Re: Vag com - Hall sender (G40)?!"£$
« Reply #1 on: 16 April 2008, 20:06 »
Pete taylor should know - Come on pete - where are you!
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 16 April 2008, 23:10 »
I know the hall sender is on the side of the dizzy....but the wiring also splits on these giving an error code
does it run ok??
Offline al_bey
« Reply #3 on: 16 April 2008, 23:21 »
Does it rev past 5000rpm?
« Reply #4 on: 17 April 2008, 10:34 »
Yes it seems to run ok ish - its been standing for 3 months so we expected it to run a little lumpy - It revs quite well past 5000 rpm - I will check the wireing on the side of the dizzy - hopefully its just a short thats giving this fault code - will let you know!
Just noticed  - The car has had a new dizzy fitted recently & I heard someware on this site that if the timing has been played about with and not set up correctly it will show a hall sender fault - but not sure :undecided:
« Last Edit: 17 April 2008, 14:56 by difficultrogue »
« Reply #5 on: 17 April 2008, 14:57 »
bump
  • Back in a Mk3...
« Reply #6 on: 18 April 2008, 07:56 »
If the dizzy is miss timed that can give a hall sender error as the readings are out of its limits... could be worth checking the timing
« Reply #7 on: 18 April 2008, 13:08 »
Me mate is coming over at the weekend with his timing gun -not sure if it will find too much wrong as the old girl runs sweet - we will have to wait and see!
Offline AndC
« Reply #8 on: 19 April 2008, 18:01 »
« Last Edit: 19 April 2008, 18:36 by AndC »
  • Back in a Mk3...
« Reply #9 on: 19 April 2008, 18:45 »
first make sure the dizzy is timed correctly before checking the cam timing as i've seen some with correct cam timing but the dizzy out 180 degree... haynes can help with the dizzy
