Author Topic: Vag com - Hall sender (G40)?!"£$  (Read 2148 times)
Offline dubmad
  • dubs all the way
Re: Vag com - Hall sender (G40)?!"£$
« Reply #10 on: 19 April 2008, 18:56 »
Quote
i should think the hall sender would fit. but i would try the coil fist as this is wat went on mine .it cut out at high ish revs for a few months and then it cut out and would not start a tall. i tryed a mates fist. hope this helps
http://
Offline Pete Taylor
« Reply #11 on: 19 April 2008, 19:59 »
Could be a broken wire as they are known to break that side of the block. As said, most likely to be the dizzy timing slightly out rather than cambelt out a tooth. The new dizzy could of been fitted because of that fault and not cleared when fixed, you should clear the faults first, run the car for a few days and scan again to see if it comes back
Offline firstgolfgti
« Reply #12 on: 19 April 2008, 20:04 »
As pete says a broken wire could be quite possible. I had a similar thing a while back found out that the ECU pulse wire from the dizzy to ECU was making an intermittent connection replaced this problem solved.
Offline difficultrogue
« Reply #13 on: 19 April 2008, 20:45 »
pete - just re vagged the ecu after reseting on thursday & the Hall sender (g40) fault code is still there! but considering the car sat for 3 months it runs like new - after replacing a split vac hose - should have the timing checked on sunday - will post back findings! :smiley:
2golfshis/hers
« Reply #14 on: 20 April 2008, 10:27 »
I got the same problem mate who I just bought my car off said he had the cam belt off 6 times to make sure the timing is correct but still it won't rev over 5000 revs. But it still run really sweet need to get hold of a haynes manual then
