Author Topic: lights on under bridges  (Read 4961 times)
Offline joesgti
« on: 16 April 2008, 09:37 »
when following Gaz the other day on the motorway, everytime we went under a tunel his lights went on and then turned off automatically when he came out. do all ed30's do this and how do i do it  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline rombonie
Re: lights on under bridges
« Reply #1 on: 16 April 2008, 09:41 »
You can switch them off completely if you want to or have them set to come on like that :)
Offline joesgti
« Reply #2 on: 16 April 2008, 09:51 »
how do i set it??
GTI MK5
NewGolf
« Reply #3 on: 16 April 2008, 09:53 »
Just turn the light switch onto "Auto", when its dark they will turn themselves on/off depending on the light that the sensor receives. The sensor is at the top of your windscreen where your rear view mirror mounts on the glass. It also detects rain and puts your wipers on if they are in Auto.
This is assuming you have the sensor   :smug:
Komenda
« Reply #4 on: 16 April 2008, 09:56 »
If you have autolights your switch will have four positions. The completely off position is at 11 o clock, auto lights is at 12 o'clock.
If you only have three positions then you don't have autolights. Hope that helps dude.
NewGolf
« Reply #5 on: 16 April 2008, 09:58 »
Good job on finding a pic, I was just about to go out and take a photo of mine and the sensor  :laugh:
Offline joesgti
« Reply #6 on: 16 April 2008, 09:59 »
hey that helps alot cheers!!! so if you leave it on the auto one, then leave your car, will it set off the beeping alarm or can it be on this setting all the time??  :huh:
GTI MK5
Offline SteveS
  • GTI ED30
« Reply #7 on: 16 April 2008, 10:08 »
didnt your dealer tells u this?? lol
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline Greenouse
« Reply #8 on: 16 April 2008, 10:15 »
On occasions I have put my lights on manually (the light sensor seems to have a mind of it's own!) then forgotten to turn them off when I got to work, they have gone off as they would if the auto function was set.
Offline gazbutmk5gti
« Reply #9 on: 16 April 2008, 10:48 »
Just leave it in that position all the time, if the lights have been on they will turn themselves off after a short delay when you get out. Think they call it comin home lights or something
Revo stg2+ & lots more
