Author Topic: Chip or re-map?  (Read 10476 times)
Offline Ess_Three
Re:Chip or re-map?
« Reply #70 on: 04 October 2010, 09:36 »
shocking :shocked: whats your mpg like? :evil:
Mid 20s I suppose.
Chasing BHP doesn't come cheap...so an ABF making 190+ BHP and running a close ratio, low geared gearbox, uses plenty of fuel.
It's quick though...  :grin:
..but gaining motorcycles.
Re:Chip or re-map?
« Reply #71 on: 04 October 2010, 09:39 »
Mid 20s I suppose.
What gearbox are you running these days, I quess a standard set up is not man enough to cope
Offline Ess_Three
Re:Chip or re-map?
« Reply #72 on: 04 October 2010, 09:45 »
Gemini/VW Motorsport 6 speed 02A conversion, running semi-straight cut gears, uprated selector bushes & pins, synchros, additional 6th gear oil feed, Peloquin LSD, 4.2 FD, MTS Motorsport upper and lower shift tower bushes...and a very light 'special' flywheel.
The 'ultimate' NA 02A fast road/track gearbox, in my mind.
Standard could cope...but I wanted as closer gear kit...so it's now geared for 145MPH @ 7300 in 6th (fuel cut)....which it will pull.
Offline Khare
  • The bear that khares
Re: Chip or re-map?
« Reply #73 on: 04 October 2010, 13:18 »
How much is that gearbox worth Glen?
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: Chip or re-map?
« Reply #74 on: 04 October 2010, 13:46 »
With these three mods my R reg 2.0 8v GTi now kicks out 150bhp and has shattering accelaration
Simon.
I think I just wet myself loling  :rolleyes: cracking thread
Just shows how much marketing bs works and how few dynos actually read accurate figures
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline Khare
Re: Chip or re-map?
« Reply #75 on: 04 October 2010, 14:03 »
before chipping i would recommend three upgrades...
1. Decent Exhaust System (mine's a Powerflow from cat back)
2. Good induction kit (I have a large K&N with cold feed straight from the lower grill)
3. Fuel boost valve - there is a  problem associated with 2.0 8v gti's - if you go with the first two options  this should give you a power increase of about 15bhp however - not bad 13% gain but you'll find that the induction kit is sucking in too much air. basically there is a delay with the fuel injectors which results in a delay in acceleration and when you get to about 5000rpm the engine starts to back off - here's where the boost valve comes in. Essentially you can alter the boost which basically rams fuel into the injectors a t a constant pressure resulting in no power lag, crisp pulling and much more torque imy car now pulls and keeps pulling all the way to 6000rpm and above - makes it drive better to!!
With these three mods my R reg 2.0 8v GTi now kicks out 150bhp and has shattering accelaration and more to the point is lot of fun!! plus it drives sooo much better.
Everyone goes on about the 16v - yeah sure its faster but you have to wind it up and keep it up - the 8v has bags more torque and is much more drivable in my humble opinion.
Chipping next on my list - i wanna get into VR6 territory but without the fuel consumption and running costs!
Simon.
Simon.
Agreed, I'd love to find this Simon so I could laugh in his face. Sounds almost as if he's trying to sell these power boost valves.
Offline Jimp
Re:Chip or re-map?
« Reply #76 on: 04 October 2010, 14:53 »
Porn  :grin:
Not low enough mk5
Not on the road enough mk3
Offline Ess_Three
Re: Chip or re-map?
« Reply #77 on: 04 October 2010, 15:06 »
Probably about twice what the car is worth!  :embarassed:
Offline Khare
Re: Chip or re-map?
« Reply #78 on: 04 October 2010, 15:10 »
Ouch! I've always been interested in playing with straight cut gears and the like, but obviously it would be an expensive hobby!
