Author Topic: Headlight washer jet question ?  (Read 2680 times)
Offline 182_blue
« on: 12 April 2008, 21:51 »
is it possible to get them to stay out (like they are when spraying) , so they can be inspected
Offline TagnuT
  • Edition 30
Re: Headlight washer jet question ?
« Reply #1 on: 12 April 2008, 21:54 »
Don't know thats a new one.
If they pop out you could grab one or put some thing across the opening to stop them returning. Just mind your eyes    :rolleyes:
Bye Bye Edition 30
Offline 182_blue
« Reply #2 on: 12 April 2008, 21:56 »
i thought of that, but i reckon that would damage the motor, all i want to do is check my drivers side one as it looked ever so slightly loose the other day, which is ok as long as it doenst fall off, i just want to make sure all is ok
Offline TagnuT
  • Edition 30
« Reply #3 on: 12 April 2008, 21:59 »
Do they have a motor or do they walk with water pressure?
Have you tried looking in TT's manuals?
http://www.golfgtiforum.co.uk/index.php?topic=54324.0
Bye Bye Edition 30
Phil mcavity
« Reply #4 on: 12 April 2008, 22:05 »
just pull up to the kerbside, make sure you have too much soap in the screenwash bottle, put the lights on and pull the lever!. great fun for spraying annoying teenagers with hoodies on. My laser blue GTi used to have a extremilly powerful jet!.
I dont know why would you wanna inspect them , if both are jetting water on the lenses then whats the problem??. like whats been said, you could bust the motor and nozzle jets.
Offline 182_blue
« Reply #5 on: 12 April 2008, 22:11 »
if you read my post above you will see why i want to inspect them
Offline Hurdy
« Reply #6 on: 12 April 2008, 23:27 »
Maybe it is a job for someone who knows about the intricacies of VAG-COM?
Seat Leon Cupra Black 290 DSG
NewGolf
« Reply #7 on: 13 April 2008, 08:44 »
I'll hook mine up to Vag Com and see if I can get them to stay out somehow, maybe theres a test feature or something. I'll post back what I find.
NewGolf
« Reply #8 on: 13 April 2008, 09:18 »
Hmmm all I can find is
-Adjust headlight washer delay and activation
-The headlight washer delay and activation can be adjusted via bytes 5 and 6.
-To disable the headlight washers, uncheck byte 1, bit 1.
Offline 182_blue
« Reply #9 on: 13 April 2008, 09:29 »
cheers for trying, its probably fine as i think they pivot slightly when they are out, so this is just a slight bit of play
