Author Topic: Distributor Help!  (Read 667 times)
Offline reubenwilliams
Distributor Help!
« on: 12 April 2008, 16:45 »
I have broken a clip off my Beru distributor on my 8v GTi Mk2!  Does anyone know where I can get a new clip or how to remove the distributor?  If I can only get hold of a different make distributor will the connections be the same.
The metal clip is not the screw on type!
Cheers all
Offline takethefifth
Re: Distributor Help!
« Reply #1 on: 16 April 2008, 00:27 »
For removing you can use this which someone kindly hosts;
http://www.iol.ie/~kilkennyhockey/BentleyManual/
If you ring GSF or ECP and give them your car details they'll send you out an appropriate replacement.
