Golf mk2
starter motor
Topic: starter motor (Read 2041 times)
jasonpi
starter motor
17 April 2004, 06:22 »
well i think its on its way out
getting a full charge but nothing when i turn the key! is it a hard job, is there a quick fix? needs to be sorted for newark otherwise you lot will have to bump start me
mk28vpb91
Re:starter motor
17 April 2004, 09:10 »
Check the connections at the motor and battery are clean before buying a new starter. Can you hear any noises when you try to start?
jasonpi
Re:starter motor
17 April 2004, 09:42 »
sometimes yes sometimes no
Blue MK2
Guest
Re:starter motor
17 April 2004, 09:50 »
wat happens exactly?
does it stop turning over like its stuck, then if you wait a minute it starts?
Last Edit: 17 April 2004, 09:50 by Blue MK2
Veedubgt18v
Guest
Re:starter motor
17 April 2004, 11:52 »
sometimes the dog wheel thing needs greasing, take it off and have a good look also clean all the connectors to it and see what happens.
WARNING the bolts mounting it are part of the front engine mount so the engine will need supporting
Veedubgt18v
Guest
Re:starter motor
17 April 2004, 11:53 »
Does a starter motor from a 1.6 fit and old 8v gti? cos if it does i know some one who has a recon one lying around jason
Dizzie
Forum addict
Make friends with your fast
Re:starter motor
Reply #6 on:
17 April 2004, 15:30 »
try connecting a jump lead from your negative on the battery to somewhere on the engine. I've just had the same problem and mine turned out to be the strap that goes from the gearbox to the shell of the car (aka the earth lead). it had corroded over the years and was making too much resistance. only ?1.90 for a new one. it's a lot better now. I also bought another starter for ?20 from the scrappy.
Last Edit: 17 April 2004, 15:31 by Dizzie
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
jasonpi
Re:starter motor
Reply #7 on:
17 April 2004, 21:24 »
well fingers crossed i left the battery on chjarge allday and it seems to have done the trick thx guys
Dizzie
Forum addict
Re:starter motor
Reply #8 on:
18 April 2004, 00:27 »
I'd still replace that strap if it looks a bit old. it's made everything better on my car now. the wipers move much stronger and my ICE doesn't cut the bassline out when you've got it wound up like it use to. had it flat out for a good 15 mins today and was perfect all the time.
Golf mk2
starter motor
