Golf mk5
Paint chips
Topic: Paint chips (Read 2440 times)
Phil mcavity
Guest
Paint chips
11 April 2008, 23:54 »
anyone know whats the cheapest way to sort a few bonnet chips out without going down the full respray route?? costing etc?
and NO not a full carbon fibre answer Hurdy, already thought of that one!
Last Edit: 11 April 2008, 23:56 by Phil mcavity
vanders
Re: Paint chips
12 April 2008, 08:20 »
As I'm not at all practical, I would get a quote from Chips Away or similar. You do not have to go with them if you don't like the price - not much good to you but there is a guy I have used locally in Norfolk (Scuffs) who is ace and very reasonable. Maybe you have got an equivalent nearby.
duzza
Here all the time
Re: Paint chips
12 April 2008, 08:50 »
paint, sand, polish - it's easy!!
GTI Edition 30, Metalic grey, MFD2, Highline, R32 Wheels
182_blue
Re: Paint chips
cheapest way is to blob some touch up in the hole and cut it back with very fine wetndry paper, i have seen some really good jobs this way
Hurdy
Serious forum addict
Re: Paint chips
12 April 2008, 11:16 »
APART FROM A NEW SHINY CARBON FIBRE BONNET
I agree with Blue. A dab of matching touch up paint, allow it to dry for 30 mins, the extra fine wet and dry paper on a small sanding block (ensures the paint gets sanded back level
). If you want you can still put a fine spot of clearcoat laquer over the top to match the gloss effect as some paints don't polish up or match correctly until the clearcoat is added
Seat Leon Cupra Black
290
DSG
Merlinman
GTI forum regular
Tornado Red 170ps GT Sport
Re: Paint chips
12 April 2008, 11:35 »
Just get the bonnet painted by a proper bodyshop - £150 ish
You'll never be content otherwise
182_blue
Re: Paint chips
Reply #6 on:
12 April 2008, 11:50 »
i wouldn't do respray route, they never look right imo, texture looks different at the very least
Phil mcavity
Guest
Re: Paint chips
Reply #7 on:
12 April 2008, 11:54 »
not sure id have the balls to sand down the bonnet with wet n dry, and try polish the back out of know what red can be like to match. i guess is it use t-cut then polish/wax to get finished result?.
Hurdy
Re: Paint chips
Reply #8 on:
12 April 2008, 12:01 »
I'd never use T-cut, swirl mark city if you're not careful
Stick to a very limited area around the chipped area and try not to go over the are by too much. It will reduce the paint correction area when you get back to polishing and waxing.
290
DSG
182_blue
Re: Paint chips
Reply #9 on:
12 April 2008, 12:11 »
you dont need to sand it, its just easier, you can use a langka based liquid product to cut it back, Red is reasonably hard to match shade wise (as a repsray would be), then again as its non metallic it will be easier than a metallic to touch up
Golf mk5
Paint chips
