Author Topic: Paint chips  (Read 2439 times)
Phil mcavity
Re: Paint chips
« Reply #10 on: 12 April 2008, 12:19 »
yes i think i will try my luck at touch up firstly. i have a steady wrist as proven when pint in is my hand  :wink:.  There is at least 6 tiny chips i found so far so will see how it goes.
Offline 182_blue
Re: Paint chips
« Reply #11 on: 12 April 2008, 12:24 »
DONT use the supplied brush, either buy a very fine artist one, or use a cocktail stick
Phil mcavity
Re: Paint chips
« Reply #12 on: 12 April 2008, 12:27 »
i am the party sausage on a stick lover, so have plenty of sticks. cheers for the advise blue  :wink:
Offline 182_blue
Re: Paint chips
« Reply #13 on: 12 April 2008, 12:32 »
if done properly they can be near invisible, good luck
Phil mcavity
Re: Paint chips
« Reply #14 on: 12 April 2008, 12:33 »
i guess once paint is dry, use cocktail stick again with laquer?
Offline 182_blue
Re: Paint chips
« Reply #15 on: 12 April 2008, 12:39 »
yeh completely or you will pull old paint out, you can mix the paint in with the lacquer and not need to top off, but i would test first, you may find you need a secon paint application though as the paint can sink (dependant on hole size), below is a guide to help you
http://www.detailingworld.co.uk/forum/showthread.php?t=20127&highlight=chip+touch+up
goes from this
to this
« Last Edit: 12 April 2008, 12:41 by 182_blue »
Offline TagnuT
  • Edition 30
Re: Paint chips
« Reply #16 on: 12 April 2008, 22:04 »
The link says use fairy liquid. I would use a "bar" of soap as that  cloggs the "grit" up even further and makes the wet & dry smoother, less abrasive.
Nice link 182_blue :afro:
Bye Bye Edition 30
