Author Topic: front speakers not working  (Read 1867 times)
Offline daniel-1986
« on: 07 April 2008, 13:51 »
my front speakers hav stopped workin all of a sudden. took them out to see if it could be the crossovers as i hav put the on the inside of the door cards but still dont work, they work off the headunit as they are amped so there must be sumthin wrong with the amp but dont no why and nothing has changed on the amp.l
any ideas
Offline jv
  • Administrator
Re: front speakers not working
« Reply #1 on: 07 April 2008, 13:58 »
is power reaching the amp? amp fuse ok?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline daniel-1986
« Reply #2 on: 07 April 2008, 14:17 »
theres power getting to the amp so it must an internal problem
Offline vr4000d
« Reply #3 on: 07 April 2008, 16:37 »
try another set of rca`s
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
« Reply #4 on: 07 April 2008, 20:43 »
When the speakers are running off the amp, Check the "continuety" using a multimeter to see there  is a closed circuit for each speaker to eliminate it being a broken wire or contact ant any point between the amp and speakers.
As previously mentioned by another post, check using a different set of Phono leads.
N if u can get hold of one, then test a different amp in the same position!
Has the amp light changed colour or has an additional ligt turned on along with the power (protection light)
If thats the case then u either have an earthing problem or your amp has packed up!
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
