Author Topic: flat spots on my mk3 gti 8v please help  (Read 3767 times)
Offline jamie snow
« on: 06 April 2008, 14:54 »
 :sad: can any one help i have a very nice mk3 gti and its all good apart from when i put the foot down it has flat spots on differant rpms has anyone got any ideas please
thanks jamie
« Last Edit: 27 April 2008, 18:21 by jamie snow »
Offline Pete Taylor
Re: flat spots on my mk3 gti 8v please help
« Reply #1 on: 06 April 2008, 16:31 »
Do you have an induction kit fitted?
Offline jamie snow
« Reply #2 on: 17 April 2008, 16:01 »
no the engine is standerd but ive got another problem now the car cut out yesterday and will not start
Offline flex
« Reply #3 on: 17 April 2008, 16:13 »
hmmm i had a kinda similar issue with mine recently the engine would cut out when the revs dropped (i thought it was not idling at first). I bought a cheap diagnostics lead and software from ebay called vag com and plugged it into my car which gave me a fault code regarding the engine speed sensor (aka crankshaft impulse sender). Im glad to say that fixed it and im back on the road and it was all DIY without paying any garages loads of cash i aint got.
I would recommend you get one and see what comes up. Its worth a shot if your stuck.
Offline jamie snow
« Reply #4 on: 18 April 2008, 10:44 »
how much did that cost then ill have to buy one for the car
Offline jamie snow
« Reply #5 on: 18 April 2008, 10:45 »
the sensor i mean
Offline marky GTI
« Reply #6 on: 18 April 2008, 10:57 »
thanks jamie
hiya mate...
i had the same problem with my 8v, i had a flat spot when i put my foot down, also it would cut out now and again but would start back up.
The problem was a pipe comeing off the top of the head going down to the bottom end, it had a hole in it about the size of a 10p peice.
Its now running like a dream with no problems
Hope this helps!!!
Offline bad-vw-boy
  • Man on a golf mission
« Reply #7 on: 18 April 2008, 11:00 »
i have the same problem if i come to a stop some times the revs drop off and the car stalls, its getting embarrasing... :sad:but she is also a bit lumpy ...i suppose flat spots...not to mention the heat shield on the down pipe has come loose and is ratteling....if it dont rain...then it just pours :cry:
Offline jamie snow
« Reply #8 on: 18 April 2008, 11:06 »
hello marky were abouts is this pipe then on the engine
thanks
Offline marky GTI
« Reply #9 on: 18 April 2008, 11:12 »
thanks
i'll get a photo of it and i'll post it on here for you.
