Author Topic: Sky high oil temp HELP!!!!!!!!!!!!!!!!!!!!  (Read 2049 times)
Offline 1982.rpd
« on: 06 April 2008, 12:30 »
Yesterday my car started overheating. I'm doing ATF flush at the moment, but yesterday and today the car overheats quickly and stinks, the coolant was boiling over and there was smoke coming out of the rocker cover the oil temp was up to 160 and buzzing, any ideas? Dont wanna go to the crap garages around by me and be ripped off.
I did wonder if doing the ATF flush might have clogged something up to make it overheat, the engine was quite dirty before.
Offline Conker
Re: Sky high oil temp HELP!!!!!!!!!!!!!!!!!!!!
« Reply #1 on: 06 April 2008, 12:35 »
Cripes! Someone on here will be able to confirm this, but at 160 degrees I think you'll might have to get the head removed and skimmed due to likely warping. My guess would be head gasket failure or your oil pump has gone.
Sorry to hear that fella.
Offline cняis
« Reply #2 on: 06 April 2008, 12:38 »
did the oil light come on straight after the oil change? low oil pressure? as said above, could be a knackered oil pump
Offline 1982.rpd
« Reply #3 on: 06 April 2008, 12:40 »
No was running sweet for a week then this!! :cry: was servicing her tomorrow, how difficult is an oil pump change??
Thanks
Offline Conker
« Reply #4 on: 06 April 2008, 12:44 »
Apparently its not too bad if the sump comes off okay, but you need to properly diagnose the problem before you go wading in.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #5 on: 06 April 2008, 17:24 »
The oil flush can block the pick up for the oil pump. Remove the sump and take a look, the oil pump is not that expensive so is worth changing it anyway while you are there. Gscp's do them, think i recall them being about £15-20. very easy to change, then just pray then you havn't done any damage.
Offline cняis
« Reply #6 on: 06 April 2008, 17:34 »
this would perhaps explain why, when my oil was flushed and changed 2 weeks ago, we couldnt get oil pressure for a while?
Offline Khare
  • The bear that khares
« Reply #7 on: 06 April 2008, 17:58 »
i havent bothered to look through the replies, so i dont know, but what about oil cooler? might have a blockage or crack or something?
Offline Conker
« Reply #8 on: 10 April 2008, 20:48 »
I don't think its that - You can run the engine without the cooler on a 16v temporarily (e.g. if its leaking), so it must only give you a few extra degrees worth of cooling, say between 5 and 10 degrees (a guess!).
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #9 on: 10 April 2008, 23:13 »
Let me get this right, you've flushed you engine with an "automatic transmission fluid flush"... Please clarify!
Tom
